electrical gremlin
Old Apr 8, 2013 | 05:33 AM
som69's Avatar
som69
Default electrical gremlin
Hi guys - this is my first post here - usually on the softail side.
Bought a 94 wide glide for a winter project and am very pleased with it so
far, only had 6k showing but who knows. Runs great and everything works
excep the turn signals, all the lights work and the switch test shows they
are good, the rear lights blink fine but the front lights light but do not blink
also the front lights are dim losing 1.3 volts from batt to lights.. anyone
have any ideas.....
Old Apr 8, 2013 | 12:04 PM
grbrown's Avatar
grbrown
Welcome to Evo ownership!
Likely problems are poor ground connectors, a damaged wire, rusty bulb holders, iffy bulbs. If you know the rear lights work fine, try swapping the rear bulbs to the front. If there is no change start the witch hunt! Work from the bulb holders along each wire, checking as you go. Dismantle every connector, clean and reassemble, then check again.
Best of luck.
Old Apr 9, 2013 | 12:16 PM
Steve12's Avatar
Steve12
I had a similar fault it turned out to be a corroded
Connection on orange wire going into plastic plug
On flasher unit attached to front fork?
It looked fine at rear of plug and at other end it was slightly rotten in middle causing short.
A quick wiggly sorted it but not for long?
I decided to rewire using moto gadget m unit
Not too difficult to do once got head round way it works
Old Apr 9, 2013 | 09:56 PM
Broncobilly72's Avatar
Broncobilly72
Had a similar problem on my old 93 Dodge W250 pickup. It was a bad main ground. Check your ground and go from there. Look into other issues after that - as Graham mentioned.
inhershey
Electrical/Lighting/Alarm
13
Jul 24, 2017 11:53 PM
2015Harley48
Apr 10, 2017 04:01 PM
Adumb
Sep 7, 2014 02:34 AM
Long124
May 16, 2013 11:48 AM
cmose
Mar 24, 2012 03:40 PM
