im about 100% sure its not your intake if it was it would spit and spudder but not front to back when mine was cracked it idled fine just when i reved it it poped and cracked but what your saying happin to me and i had to replace the ignition module
Just pull the wire and stick a screwdriver in it and see if it sparks to a fin and jumps a pretty good gap, if it does, you already tried a plug, move on to fuel or compression.
Does front cyl pickup any with enricher or hand choking at fast idle?
Seems like it is safe to say your coil is fine and you have a spark. Check the sending unit in the nose cone it is usually obvious if they are blown, do a compression test ensure gas is reaching the jug should be obvious on the plug. If that all checks see if your buddy will let you try his ECM. Start with the simple and cheap the work your way up.
Great spark jump. And only the rear cylinder picks up when I use the choke.
Thanks guys I got some work to do. Any suggestion on type or brand of compression tester? Tried on that was from oriellys and I almost couldn't get it out of the jugs.
