yeah LockTight use your thumb for something usefull for once haha
Im going to shake the living s*** out of you when I see you friday Porkchop!
Originally Posted by texashillcountry
It isn't weird it just means your problem is not in the ignition circuit.
You said you get spark on the front plug so you have to have a problem in the front jug.
Do you have adjustable pushrods in your bike?
You said you had a hard time getting the O'Rileys compression tester out of your jugs. What did you get when you did the compression test?
Did you do a leak down test?
If you plan on working on your bike yourself you really need a OEM service manual.
Do you have one?
I have adjustable push rods as of this weekend when I did the cam swap this weekend, but ive had this problem on and off for about a month or two. I could'nt get a good compression check because of that. I have to shop around. Gonna try the leak down test. How ever while the motor is at idle it will push your hand off if you cover the front pipe.
so you are covering the exhaust pipe?Tke the plug out and listen after it blows your thumb off the sparkplug hole for the exhaust ---------determine if you are close on engine phasing
Yeah I wanted to see if it was kicking out hot exhaust. What am I listening for a stuck valve?
All the motorcycle safety courses in our area offer the bike to take the class. Might not have to have your bike fixed...then again, maybe you do for your class.
The level 1 training can be done on a trainer bike. Level 2 has to be done on your own bike according to the military requirnments.
Have you checked the push rod adjustment....they are notorious for causing issues like this. Take them out and refit as per instructions.
