After 7 1/2 years and about 50k miles, I'm getting a miss every now and then under load. I'm guessing the coil and the ignition sensor are both original, 25 years and over 100k miles. So I've ordered new plug wires and a new coil. Other than that I'm thinking of throwing a new pickup in there to. Anything else I should consider being the cause? It's never done this before now.
Maybe I can throw on a little miss about 18 or 19 y/o
That's why I'm thinking about replacing it and go through all the connections, that way I'll "know" it's good, barring the fact my new module could be bad right out the gate.
Mine would cut out completely for a few seconds, then start up again. I chased that one for years until finally it cut out and didn't restart. It was the wire going to the sensor in the cone. It was broken inside the insulation.
Yea, the wires going into the cone are ugly. So I'm thinking I'll just replace that. Anything to it? I've had the cone off a couple times, just put the sensor back where it was when I took it out. Will the new one just go back in where the old one was, or will it need to be timed?
I suggest at least checking the timing. It's easy (with a timing light.) You don't even need the clear plug, just leave it open and tolerate the oil mist.
Go for the plugs before the expensive stuff Bro !!!
