Transmission Gears
Old Apr 23, 2013 | 06:45 PM
jdm1200's Avatar
jdm1200
Default Transmission Gears
Ok I'm broke down waiting on my wife to come pick up bike and me in Texas
I somehow managed to break the gears in the tranny. So while I'm waiting are there any reccomendations for the best gears to put in my 86 FLHTC?
Old Apr 23, 2013 | 06:47 PM
B-Sweet's Avatar
B-Sweet
Default Where R U
Whree R U in Texas???
We can come help if needed, we are just south of Ft Worth.
Old Apr 23, 2013 | 06:53 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Just west of Austin here.
Do you need anything?
Old Apr 23, 2013 | 06:57 PM
Tom84FXST's Avatar
Tom84FXST
I have an 83 FLHT trans with 13k original miles sitting in my garage....should bolt right in..PM me if interested.
Old Apr 23, 2013 | 07:01 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Why don`t you tell us what is wrong?
Old Apr 24, 2013 | 04:30 AM
grbrown's Avatar
grbrown
If he's stuck on the roadside he may not know yet! Would be interesting to know more about the symptoms though.
Old Apr 24, 2013 | 10:53 AM
jdm1200's Avatar
jdm1200
Wow I'm sorry for not getting back on here. I really apologize. I got distracted by other people, worked on the bike a bit and then the wife showed up and I drove till 3 to get home. I am sorry I left y'all hanging.
We took the tranny cover off and the gears have broken teeth that are rattling around inside and locking things up. I won't be sure if all the damage till I get everything out and inspected. Looks like a few gears at the least possibly a whole new gear set. I was looking at the RevTec 6sp gear set that will fit in the 5 case.
Thank y'all so much.
Old Apr 24, 2013 | 10:56 AM
jdm1200's Avatar
jdm1200
We stopped for gas and upon leaving I gave a little more throttle than usual due to another vehicle and then there was a pop followed by grinding from the tranny with periodic locking up then all ability to shift went away. That's when we took her back to parking lot and took the cover off and discovered the gears.
Old Apr 24, 2013 | 04:13 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Much cheaper to replace the gear set with a good used one. Buying individual gears can get very expensive. If you are planning to stick with the same clutch setup, you can use any `89 or earlier 5 speed gearset (tapered mainshaft).
Old Apr 24, 2013 | 05:07 PM
1984_FXRT's Avatar
1984_FXRT
If your question is about brands - stock used is gonna be your cheapest bet, and an Andrews gearset is most likely the best in terms of ability to withstand hard use, but, the Andrews stuff's gonna be a bit pricier.
