Head work or pistons?
Made a mistake with too much compression and early intake closing resulting in starter eater, detonation, hot temperatures affected runabiltiy but boy would your teeth slide back when you rolled into it but costed a heated cylinder. Trying to relay the school of hard knocks and already went thru the Jello brain stage plus with my current engine I had a hall of fame engine builder that did my heads in my corner spewing knowledge of targeted real world compression in any conditons, learned alot by asking questions and then listening to experiance
A great combo we've used here for waaaaaaaay over 15 years is to remove .065", with a .030" head gasket, and install a Wood 6.
Must've built 80-100 Evo's over the years with that set-up.
It'll hover at 80 hp, and 90 ft/lbs.
Scott
Would removing .065" on the heads, with .030" head gaskets - work as well with the EV27 cam, as it would with the Woods 6?
I just got back from talking to the shop doing the headwork and this is what we decided on.
I'm having .050 shaved off the heads along with a competition valve job, bowls blended, D-cut in the combustion chamber and porting. I'm not touching the cylinders or pistons. They will stay stock for now. I'm installing an EVL-3010. My compression should be 9:1 according to the shop doing the heads. I'm sticking with the stock cometic MLS head gaskets which if I remember right measured .043. I brought up using the .030 gasket and he cautioned me against it because he was afraid I might get some pinging.
We have it set up like this so that later on if I decide I hate the EVL-3010 and want another compression bump to accommodate a different cam I can have him open up the cylinders by .005 or .010 and put in some KB domed pistons.
Once I measure my deck height I am going to bring the cylinders down to the shop to make sure the bases are square. I did some dremelling with a scotch brite wheel to get the baked on gasket material off so in hind sight I decided to have them checked.
Now I just need to get some ez-adjust rods and I should be good to go.
Then I just have to wait for Avon to get's its *** in gear and ships my 2 replacement tires.
Aces, I don't have the cash flow for pistons and cylinder boring right now. Im way over budget now. This was just supposed to be a cam swap/gasket replacement. When I yanked the heads and tested them I found the needed a valve job. If you're gonna get a valve job you might as well get the heads done up. Doing the heads killed my budget. Also, the 10:1 wouldnt work well for the cam I choose according to the head guy.
