Evo shuts down after 20 miles
Old May 16, 2013 | 02:58 AM
  #61
BOCR6's Avatar
BOCR6
what should i look for in the nose cone?
  #62
Jackie Paper's Avatar
Jackie Paper
Remove the air filter and carefully hit it with a spray of starter fluid while cranking and see if it will run a few seconds. Follow instructions of can carefully.
Old May 16, 2013 | 04:04 AM
  #63
BOCR6's Avatar
BOCR6
is that to see if the problem is fuel related?
Old May 16, 2013 | 05:40 AM
  #64
LeFat1's Avatar
LeFat1
its to see if there is an intake leak, i've had similar problems as you some being as simple as a bad new set of plugs to poorly connected electrical connectors...recently had found my crank position sensor to be dirty...keep looking you'll find it...tech 101, replace suspected parts with KNOWN good parts
good luck, its a bitch especially if u want to stay away from the stealer
Old May 16, 2013 | 07:17 AM
  #65
Jackie Paper
Post 62 is is just to see if it's fuel related. Of course if it's flooding that will not help. However if it's flooding you ought to smell a lot of raw gas. It has to be at least running to do what Lefat is talking about and then you spray a little propane around manifold and see if it idles up to look for intake leaks.
Old May 16, 2013 | 08:01 AM
  #66
1984_FXRT's Avatar
1984_FXRT
Originally Posted by LeFat1
Thanks but that doesnt pertain to a 2003 FLSTFI
A coil is a coil - the only difference will be the expected resistance values if you have a "hot" coil. The test procedure is the same.
Old May 16, 2013 | 08:52 AM
  #67
92Fatty's Avatar
92Fatty
10/4 for test for fuel now. You can also check to see if accelerator pump is squirting fuel when you twist the throttle prior to starter fluid test.
Old May 16, 2013 | 12:30 PM
  #68
BOCR6's Avatar
BOCR6
alright so i got up early went back to basics and checked inline fuel filter and pulled the a/c off to make sure im squirting when throttle applied, both checked out fine, then i pulled the cone cover and guess what i see... i have a crane hi 4 module in there, not sure how to see if thats the problem but i turned ign on to see if the little red light on the module would turn on and it didnt, not sure if bike has to be running for light to come on, gonna look through the forum to see related issues with that ign module ive heard they crap out and thats why there out of buisness but i read that online and they cant put anything on the internet that isnt true lol, let me know what you think, thanks again guys.
Old May 16, 2013 | 01:08 PM
  #69
Dr.Hess's Avatar
Dr.Hess
Yeah, you found the problem. For a while on the board here, it seemed like we had 1 a week of "my bike won't start...", "my bike dies after it warms up..." and they always had a Crane hi 4 in there. Then Crane went out of business. Replace that thing and you should be OK. I like the OEM system with a screaming eagle module, but the Ultima/Rev Tech, I think, are pretty popular too.
Old May 16, 2013 | 01:35 PM
  #70
BOCR6's Avatar
BOCR6
seems like its goin to be an expensive "might fix it part", is there any way to test it?
