ring gear question
Old May 17, 2013 | 01:39 PM
NickSchoff's Avatar
NickSchoff
Default ring gear question
I have a 99 heritage stage 3, it eats starter clutches and now the ring gear. what would be the best ring gear to put in.
Old May 17, 2013 | 05:18 PM
Spanners39's Avatar
Spanners39
Try the low-ratio conversion, it takes the load off the starter train....or go stock and fit compression releases.
Old May 17, 2013 | 05:21 PM
1997bagger's Avatar
1997bagger
Ate a few of them before, currently running a Allsballs starter, HD battery and there is a ring gear between the stock fine tooth and thick tooth older ring gear, can't remember the name brand but this combo has been in for 7 years. Add some bigger cables too as it seems damage is caused by slower revolutions from a voltage drops and a newer battery helps
Old May 17, 2013 | 06:01 PM
miacycles's Avatar
miacycles
Did you change the engine pulley???? If you went smaller you are putting a bigger load on the starter.
John
Old May 18, 2013 | 10:14 PM
Jake911's Avatar
Jake911
I went with the 10/84 ring gear. You have to drill out the rivets in the clutch basket, but it is simple to do. Haven't had any issues like I did with the stock gears.
Old May 18, 2013 | 10:55 PM
1997bagger's Avatar
1997bagger
I believe that is the ratio I went with a made by Compufire? the stock ratio didn't hold up
gdt3
Apr 9, 2015 10:52 AM
raiderluke402
Dec 27, 2011 10:37 PM
Fireman1501
Aug 8, 2010 05:34 PM
HDF Tech
Electrical/Lighting/Alarm
Aug 22, 2009 02:32 PM
HDF Tech
Engine Mechanical Topics
Jun 25, 2005 07:13 PM
