Drilling AC backing plate question?
Old Feb 23, 2007 | 08:57 AM
RudeDog's Avatar
RudeDog
Default Drilling AC backing plate question?
I need some info on what size bit where to drill out the backside of the air cleaner assembly to get better flow to the carb. So far I've got K&N filter, Andrews EV-27 cam, SE pipes and carb mods done. Just need to get the backing plate drilled out, it's a '98 FXDS.
Old Feb 23, 2007 | 01:58 PM
fxstcguy98's Avatar
fxstcguy98
Default RE: Drilling AC backing plate question?
I would think that you could remove as much as possible that is outside the diameter of the filter element. You can't have too much air, but you need some meat for structural integrity.
Old Feb 23, 2007 | 03:09 PM
glide's Avatar
glide
Why not just get the stage 1 backing plate and be done with it as long as you have the filter?
Old Feb 23, 2007 | 06:57 PM
RudeDog's Avatar
RudeDog
glide Date 2/23/2007 12:09:00 PM Why not just get the stage 1 backing plate and be done with it as long as you have the filter?
I am on a budget, a tight budget. So far I have about $50.00 into this project (filter, O-rings and gaskets). I suppose I could go down to the dealer and see if they have an example on hand.
fxstcguy98 Date 2/23/2007 10:58:33 AM I would think that you could remove as much as possible that is outside the diameter of the filter element. You can't have too much air, but you need some meat for structural integrity.
Thanks for the reply, now I am wondering how much is too much.... Hmmm...
Old Feb 23, 2007 | 09:23 PM
glide's Avatar
glide
Check this post out https://www.hdforums.com/m_174418/mpage_2/tm.htm
firehawk6
Sep 4, 2017 10:33 PM
P51Driver
Jun 6, 2013 09:52 PM
UPSGUY
Exhaust System Topics
Nov 20, 2011 07:21 PM
RK#1
Apr 13, 2008 12:46 AM
Dr.Cool
Sep 11, 2006 01:43 AM
