I'm done! It worked! I rock!
Old May 30, 2013 | 10:48 AM
Bumpandrun's Avatar
Bumpandrun
Good to see hands on guys. Good job!!! Fellow 98 glide owner here.
Old May 30, 2013 | 04:59 PM
machinehed's Avatar
machinehed
Default oil in lifters.
Originally Posted by terrapin88
Hey Schex3x, I get a lot of smiles from women who read that sticker. Go figure? lol
Thanks for the pat on the back guys-
I'm more of a liquor guy but if I drank the amount of beers it took I'd either be passed or still pissing. Not including the time at the machine shop, I could have had this done in a weekend, but I milked it. I worked on it for a few hours here and there when I had time.
Biggest pita I think aside from getting the cement like baked on gaskets off was getting the rear wheel back on with the spacers properly aligned.
The cam swap was easy as pie. I wouldn't think twice about swapping out other cams to try. If anyone is considering it, go for it.
I did get a little stumped when adjusting the pushrods. I put in new lifters and though I tried to manually get them to suck up some oil, I didn't do very well. I kept adjusting the rods lower and lower till they wouldn't move, and come back in 20 mins thinking the lifters had bled down. I still couldn't spin the rods with my fingers. I took them out and put them back 3 times with the same problem. It wasn't till I walked over and picked up one of the old lifters still pull of oil and tried to depress it with a rod that I realized my new ones must be bone dry and I was actually adjusting the depressing the new lifters all the way down. Glad I thought about that before I tried starting it. Duh dumb ***.
I can't think of anything now that was a big deal or hard to deal with. I will say if you have your heads off and are looking to pull the springs and valves, don't bother with Autozone or Advanced Auto's spring depressor tool. Junk. I bent them. I went to my indy and he lent me a real tool and I had them off in minutes.
Same deal with the rental piston ring compressor tools. All they had were the big adjustable spring types and they sucked. I took the pistons off and put the cylinders upside down on my bench and slid the piston down into them one ring at a time. I used a couple of FMJ 30.06 cartridges to gently push the rings in the grooves as I worked them into the cylinders. I tried .308 cartridges first but they were too short.
Congrats on a big job well done with the help of a good shop to boot !
Regarding the lifters ... gotta soak those little buggers for a day in a pan of light oil and let them roll around once or twice to let the oil get in as much as possible.
Im doing the same with my 90 FLT and also hope to find the same great service from a shop i have never used before .
Enjoy your "new" ride Bro.
Old May 30, 2013 | 06:34 PM
terrapin88's Avatar
terrapin88
Thanks guys.
machinehed, I was happy to find a shop like that. It's great to have someone spend the time to make you understand what they are going to do and why.
Good luck with your FLT.
Old Jun 6, 2013 | 05:44 PM
junglejoe's Avatar
junglejoe
Hell yea bro! Sounds damn good! On a side note..that's the same damn problem I had, adjusting the valves!
Old Jun 6, 2013 | 06:02 PM
junglejoe's Avatar
junglejoe
Do you know what head gasket you used? And you had your heads shaved at .050 and still only 9:1? Just wondering...
Old Jun 6, 2013 | 08:15 PM
terrapin88's Avatar
terrapin88
I used the stock size cometic head gasket Joe. It's .043 or .045, can't remember. Whatever stock is.
PaulBartell
Engine Mechanical Topics
Nov 30, 2018 05:32 AM
Schex
EVO
11
Mar 14, 2014 10:46 PM
Mountain Guy
Dec 3, 2013 11:47 AM
Truax
Exhaust System Topics
17
Aug 8, 2009 01:49 PM
97wideglidenh
EVO
19
Feb 22, 2009 05:53 PM
