speedo problems
Old May 29, 2013 | 02:53 PM
NickSchoff's Avatar
NickSchoff
Default speedo problems
my speedo has been cutting out, it will work one min then not the next. I also noticed that when the speedo cuts out that the odometer blanks out. so at this point don't know if its the sensor or speedo. Im gonna pull the sensor out today and check it out. this it on a 99 heratige. im just looking for some input.
Old May 29, 2013 | 05:01 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Check the ground.
Old May 31, 2013 | 06:32 AM
grbrown's Avatar
grbrown
Originally Posted by texashillcountry
Check the ground.
....and the wiring between speedo and sensor for good clean solid connections.
Old Sep 12, 2023 | 11:16 PM
1madmouse's Avatar
1madmouse
Check the voltage regulator many have had that be the problem. I did last year on a 2000 FXD Superglide.
Old Sep 19, 2023 | 11:39 AM
1madmouse's Avatar
1madmouse
I had the speedo quit and odometer go blank as I rode last week on the way home. Bike ran fine, just no speedo. Ordered a Cycle Electric Voltage Regulator from LowBrow, Installed and everything is working great. I checked all the wiring and connections, found a tight spot on the triple clamp neck and corrected that. All seems good now. I got the referral from our forum.
bigsteve799
Sep 21, 2023 12:05 PM
philinms
May 31, 2007 11:17 PM
