Electrical problem?
Old Jun 5, 2013 | 07:50 AM
Glide1990's Avatar
Glide1990
Default Electrical problem?
Thanks for your help in advance . I have a 1990 electra glide with straight pipes and a kn intake. The bike will run great at low rpms and idle perfect. As soon as I hit 30 mph it wants to cut off in any gear or when I put it under load.. The carb has brand new rebuild kit it has been jetted . The intake manifold has new gaskets and the gaskets going to the head have been replaced I have no leak there. I was told it could be the ignition pick up.. So i put a brand new one on.. Didn't fix the problem .. Then I was told if that's not it could be the ignition module.. Ordered one and put that on there... SAME PROBLEM! Please help I want to RIDE!
Old Jun 5, 2013 | 07:56 AM
Jim Kraft's Avatar
Jim Kraft
Could be your carb float level is off. Sounds like it might just be running out of gas. I would sure check the float anyway.
Old Jun 5, 2013 | 08:06 AM
Dr.Hess's Avatar
Dr.Hess
Not an ignition pickup or module. Who told you that? I would suggest you not take advice from them in the future. Next, fix the carb.
Old Jun 5, 2013 | 09:24 AM
jokenroll's Avatar
jokenroll
Intake leaks would cause more problems on idle and low RPM's.
Sounds like fuel starvation indeed. are the jets clean? Is the petcock ok? Is the needle clamped properly?
Old Jun 5, 2013 | 10:26 AM
Glide1990's Avatar
Glide1990
Brand new jets... Needle is set to specs from Harley ... The guy who told me that was a Harley certified tech .. He said it was a electrical problem I brought the bike to him that's when he told me its a electrical issue.. The pickup was fried and melted that's why he told me I needed a new ignition module next after the pickup didn't fix the problem.. He said the next would be the coils after i just put the new ignition module on. Before I bought anything else I was trying to get some feedback ... I was so fed up that I couldn't get it to run so I brought it to him .. He went over it and said what he thought it was I brought the bike home and installed all the parts on it.
Old Jun 5, 2013 | 10:43 AM
grbrown's Avatar
grbrown
Does it have a VOES and is that correctly connected electrically and with an intact vacuum hose?
Old Jun 5, 2013 | 10:46 AM
jokenroll's Avatar
jokenroll
Well, if it is electrical, could be the ignition switch or one of those relays near the battery: cannot cope with higher current demands. I had something similar with my 93 decker, but not rpm related but rather electrical load related: lights, radio, etc. Just cuts of on speed w/o warning.
To check that, try to bypass the supply to your coils/ignition module - connect it to the battery directly ( make sure + goes to + though)...
Old Jun 5, 2013 | 11:56 AM
Glide1990's Avatar
Glide1990
The voes is hooked up correctly .. Would the bike still run great at idle and low rpms if the voes was bad? I was told the bike would cut off if the voes was bad they either work or don't .. Is that a true statement ? Thanks
Old Jun 5, 2013 | 12:03 PM
jokenroll's Avatar
jokenroll
I don't even think VOES would have any noticeable effect at all - it's either open or closed, and when it closes under vacuum, all that happens the advance on your ignition curve is smoothed out - that's it. You can easily ride with VOES disconnected and won't feel anything...
Different story if there's vacuum leak at VOES and it's line, but this would be like any vacuum leak - would affect you mostly on idle and low rpm
Old Jun 5, 2013 | 12:08 PM
Dr.Hess's Avatar
Dr.Hess
No, if the VOES is bad, depending on how it blew (open or closed), it could run OK at idle or at open throttle. It would certainly be worth checking. Use an ohm meter and a vacuum source like a little vacuum pump.
If your ignition sensor was melted, you needed a new one of those anyway, so that was not money wasted.
Lots of "certified" mechanics of all types don't know their *** from a hole in the ground.
You do have the shop manual for this bike, right?
