Question
Old Jul 22, 2013 | 01:14 PM
traildog's Avatar
traildog
Default Question
Why would a bike try to move forward when it's in neutral and you give it a bit of throttle?
I was looking at a used Harley, and when the guy started it, in neutral, it sort of moved forward when he revved it.
Old Jul 22, 2013 | 01:53 PM
monkeyboy22's Avatar
monkeyboy22
Clutch plates are still stuck together. Hopefully after it warms up a bit that won't happen. You'll probably notice a louder clunk when it goes into first gear for the first time for the same reason. This is why I always start my bike in neutral *and* with the clutch lever pulled in. Less strain on the starting system.
Old Jul 22, 2013 | 01:54 PM
ironoxide's Avatar
ironoxide
drag on the clutch plates I'm guessing.
Old Jul 22, 2013 | 02:26 PM
traildog's Avatar
traildog
I knew there had to be an easy answer. Thank you.
Old Jul 22, 2013 | 02:43 PM
Dr.Hess's Avatar
Dr.Hess
Improperly adjusted clutch, something broken/dragging in the clutch pack, wrong fluid in the primary, one of those "easy clutch" adapters, problem with the release mechanism. I'm sure there's more reasons.
Old Jul 22, 2013 | 03:32 PM
monkeyboy22
All good and valid points. I just spit out the first thing that came to mind.
Old Jul 22, 2013 | 03:47 PM
miacycles's Avatar
miacycles
Guys, if the bike is in neutral you can let the clutch out and the bike shouldn't move!!! Chances are the tranny lube is a little thick and the lube is trying to turn the gears. It shouldn't do it once it's warm. Of course you could also have some bearings getting a little "Tight" and dragging!!
John
Old Jul 22, 2013 | 03:51 PM
Dr.Hess's Avatar
Dr.Hess
I didn't see the neutral part. I'm sorry, my bad reading comprehension. I was thinking moving forward with the clutch in while in gear.
I'm with John.
Old Jul 22, 2013 | 04:48 PM
Spanners39's Avatar
Spanners39
It saw your Japper and was trying to escape......
Old Jul 22, 2013 | 04:54 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
