Tappet blocks seeping
Old Jul 24, 2013 | 09:28 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Uncle G.
I once had an intermittent leak from the front lower pushrod seal that drove me nuts. It turned out that the front exhaust pushrod was slightly bent-not actually "bent", but the threaded section of the adjustable pushrod was brazed to the shaft a bit crooked. Every so often, as it rotated, it would rub on the pushrod tube, and once in a while would "rock" the pushrod tube enough to break the seal at the lower o-ring, causing a leak that came and went.
Not saying that is your problem, but it's something to check for. It's most likely to occur on the front exhaust position, since that pushrod operates at the greatest angle.
Thanks for the idea I will check.
Old Jul 25, 2013 | 11:49 AM
texashillcountry
Dirt don't hurt
I put in some 50 weight this morning.
Another friend of mine told me I need to run 60 weight with the heat down here.
What do ya'll think?
Old Jul 25, 2013 | 11:53 AM
jammerx's Avatar
jammerx
Don't use synthetic unless you have new gaskets. Just run HD Dino...
Old Jul 25, 2013 | 12:13 PM
texashillcountry
Dirt don't hurt
This is not meant to be a syn vs dino thread!
It is more a weight question.
As for the HD brand they are no better or worse than what you can get in an auto parts store.
blueglide88
EVO
16
Aug 1, 2020 09:28 AM
TheBanditColorado
EVO
21
Oct 22, 2013 01:26 PM
fastmofo01
EVO
13
Jul 6, 2011 02:48 PM
BB
EVO
Sep 7, 2008 08:34 PM
77Tulsa
Jul 12, 2006 07:09 PM
