Tappet blocks seeping
Old Jul 23, 2013 | 08:09 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by traildog
Or, you could buy a ...... dare I say it?.........JAPPER! Problem SOLVED!:icon _ditto:
It is definitely time for you to check into the rubber room!!!!!!!!!!!!!!!!!
texashillcountry
Dirt don't hurt
Originally Posted by cpbedor
THC, shot in the dark but once upon a time I "overcharged" my K&N and it started dropping. There was no sign at the air cleaner cover but gathered nicely at the tappet blocks and appeared to be a massive leak from there. It was revealed to me that it was the air cleaner once I took the cover off. Don't mean to sound like a total idiot but maybe check behind the air cleaner cover...see if there's oil. Good luck
I'll look in the morning. Thanks.
Old Jul 24, 2013 | 07:41 AM
Moog Player's Avatar
Moog Player
Both blocks or just one? What looks like the rear block on mine is just the oring on the tappet screen plug seeping.
Old Jul 24, 2013 | 11:20 AM
texashillcountry
Dirt don't hurt
I noticed it first on the front tappet block.
Old Jul 24, 2013 | 11:22 AM
texashillcountry
Dirt don't hurt
Ok yesterday when I looked at the O-rings I noticed road grime in the area and like an idiot I didn't clean it then so this morning I took apart the pushrod tubes and cleaned all surfaces as best as I could with cotton swabs.
I hope that's it.
Old Jul 24, 2013 | 06:58 PM
miacycles's Avatar
miacycles
Do you have the steel rings in the lifter blocks???
John
Old Jul 24, 2013 | 07:13 PM
texashillcountry
Dirt don't hurt
John
Yes.
All the parts are there and I can't find anything wrong with the O-rings.
No cuts, no folds, no nothing that I can see.
It isn't leaking down from the air filter.
There is nothing obviously wrong.
Old Jul 24, 2013 | 08:47 PM
Uncle G.'s Avatar
Uncle G.
I once had an intermittent leak from the front lower pushrod seal that drove me nuts. It turned out that the front exhaust pushrod was slightly bent-not actually "bent", but the threaded section of the adjustable pushrod was brazed to the shaft a bit crooked. Every so often, as it rotated, it would rub on the pushrod tube, and once in a while would "rock" the pushrod tube enough to break the seal at the lower o-ring, causing a leak that came and went.
Not saying that is your problem, but it's something to check for. It's most likely to occur on the front exhaust position, since that pushrod operates at the greatest angle.
Old Jul 24, 2013 | 08:57 PM
Jim Kraft's Avatar
Jim Kraft
Just my 2 cents, but if you get that synthetic out of there and put that Castrol GTX 20-50 back in it I bet your leak or seep will stop. I know mine did. I have heard of so many EVO's running well over 100,000 miles with Castrol and mine has had it since new except for one change to Mobil 1 Vtwin 20-50 synthetic. My base gaskets started to weep with it and when I changed it back it quit. I have 40,000 on it now with no leaks.
Old Jul 24, 2013 | 09:27 PM
texashillcountry
Dirt don't hurt
The seep started when I had the Castrol in it.
Granted it got worse when I put in the syn.
