Vacuum petcock diaphragm leaking
Old Aug 7, 2013 | 08:40 AM
01fxdxt's Avatar
01fxdxt
New stock HD body kit-$28 from discounter,buy 3, they will last your bikes lifetime .Cheaper than pingle
Old Aug 7, 2013 | 08:47 AM
GPz11's Avatar
GPz11
Shoot, you should be able to get a rebuild kit from J&P also
Yes, Pingel's are pretty and work well but if you don't have the cash to drop on getting one, the cheap one will work just fine.
I've used Pingel's in the past so I'm well aware of their quality.
Old Aug 7, 2013 | 05:12 PM
Doug S's Avatar
Doug S
Either buy another OEM petcock or get a pingle. Trust me, I am as cheap as they come, the cheap ones do not work for long with todays fuels. Spend the 80 bucks, move on with your life and be safe..
Ds
Old Aug 7, 2013 | 05:47 PM
Jim Kraft's Avatar
Jim Kraft
I ran the stock Harley non vacuum petcock on my 84 Sportster for 23 years without problems. So they do last a long time.
Old Aug 8, 2013 | 09:12 PM
98glider's Avatar
98glider
My vacum petcock leaked also. Went back to the same one vacum operated . They came out with a updated one hey it is stock and they seem fine enough.
Old Aug 8, 2013 | 09:22 PM
Jackie Paper's Avatar
Jackie Paper
Gee, change the oil... 4qts..no big deal. But I doubt it got into the engine. It has a drain tube vent I think in carb but guess it depends on how much your stand leans over. The vacuum petcock lasted 17 years...Get another Harley one so you do not need to remember to shut it off much less turn it on (guarantee you'll forget both ways) plus it is a lot safer. However,you still should make an effort to turn it off and on as a backup.
Old Aug 9, 2013 | 06:36 AM
Kushman's Avatar
Kushman
I think JP Cycle has them on sale now for around 12 buck, worth looking. Or just loose the vacuum feature as mentioned. I personally hate the vacuum petcock it's a real pita if you breakdown and have to remove the tank and I am used to shutting it off anyways.
Old Aug 9, 2013 | 08:06 PM
cowboy 51's Avatar
cowboy 51
when My 94 's went out I just order from drag specials about $26 bucks here in three days that was two years ago , so had money for gas & a few beers ,& also turn it off & on a non vac will leak through & /can get into crank case , so just change your oil & filter & ride into the sunset
Old Aug 9, 2013 | 08:29 PM
GPz11's Avatar
GPz11
Everyone mentioned getting a new one from Harley. Well, I tried and was told they were no longer available for my '93 FLHTC.
No other choice but to get a aftermarket one.
Old Aug 9, 2013 | 08:39 PM
HarDlife's Avatar
HarDlife
My dealer said they had a "aftermarket" non vac for $22, and vacuum style for $35. I just ordered the JP mech one ($19) for now, might get a pingel down the road if I mod the motor up. FYI, I disassembled the stocker, flipped some parts around, and got it to work w/ no leaks. I wouldn't leave it that way but it can be done in a pinch.
