Oil usage in Evo
Old Aug 9, 2013 | 01:29 PM
bluharley's Avatar
bluharley
Originally Posted by texashillcountry
DBLJ if your going to work on your own bike you really need an OEM service repair manual.
There is a bunch of great information in there and it pays for itself the first time you use it.
Agree 100%. I'm pretty sure the primary oil level changed in that year, from the bottom of the inspection window, to the bottom of the clutch basket. If your bike is before the change, then the oil being high on your clutch basket is not unreasonable. Get the book, then you'll have accurate information.
Old Aug 9, 2013 | 02:16 PM
traildog's Avatar
traildog
Ditto x 3. First "accessory" i bought for Scarlett......She was SO happy......
Old Aug 9, 2013 | 08:26 PM
cowboy 51's Avatar
cowboy 51
yes the service manual will be the best tool in you box
Old Aug 10, 2013 | 05:05 AM
grbrown's Avatar
grbrown
Originally Posted by DBLJ
Do I need to start the bike and let the oil warm up before I check it in the primary or is it o.k. to check it cold?
Doesn't matter. It is an oil reservoir with no way in or out normally. If there is more oil than there should be that will suggest a leaking crankshaft oil seal, however don't panic!
SCHOONER
Oil Archive (no new posts)
17
Mar 24, 2014 01:33 AM
P'colaHarley-17RGS
Dec 11, 2013 08:46 AM
SCHOONER
EVO
34
Apr 28, 2012 04:48 AM
dmaxey
Apr 27, 2009 08:36 PM
chewey
13
Jun 10, 2006 09:49 AM
