Wet sump reduction
Old Aug 12, 2013 | 03:51 PM
rol427's Avatar
rol427
Default Wet sump reduction
Wet sumping is caused by too much oil sitting in thecrankcase when the engine is started. Theexcess oil is forced out of the crankcase via the breather tube and creates abig mess. The oil in the crankcase has two sources; the leftover from when theengine was shut off and the leakage past the oil check valve. The leakage is afunction of how long the engine sits without running and how well the checkvalve is working. You can reduce theremnant oil by allowing the engine to idle for a couple of minutes before turningit off. This allows the scavenge portion of the oil pump to evacuate as muchoil as possible. On my bike this can raise the level in the oil bag by aquarter inch or more. If you have a bottom breather you probably also have amanual fuel petcock. I close the petcock while the engine is running to liftthe fuel valve off of its seat while the bike is sitting.
Old Aug 12, 2013 | 04:32 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
For some reason when you cut an paste something into HDF some words get jammed together.
You have to go back and edit your post to unjam the words.
Old Aug 12, 2013 | 06:16 PM
MJHJEA's Avatar
MJHJEA
I am tired of reaing anything that has to do with wet sumping....
Old Aug 12, 2013 | 09:47 PM
cpbedor's Avatar
cpbedor
first world problems
Old Aug 13, 2013 | 07:18 PM
Rob85WG's Avatar
Rob85WG
Both of these suggestions sound excellent and I will add them to my bag of tricks to keep "Big Red" happy.
Don't forget to close the petcock and run it til the bowl is dry when the bike will be parked for a long time.
Old Aug 13, 2013 | 11:15 PM
BigT-91's Avatar
BigT-91
I have this problem and want to fix it myself if possible. Does anyone know how to fix the check ball problem?
Old Aug 14, 2013 | 12:15 AM
panz4ever's Avatar
panz4ever
Get a welding rod and weld it to the end of a good check valve and gently lap the seat area where the check ball rests. Won't take much....Clean the area real good and install a new check ball. At the same time you might want to install a new spring.
colorado rider
Dec 24, 2014 09:08 PM
guspup
EVO
11
Jun 27, 2011 03:39 PM
hdbeggs
Feb 6, 2011 07:48 PM
NDNGREG
Sep 7, 2010 03:35 PM
weewanreefer
Oil Archive (no new posts)
Jun 24, 2007 06:05 PM
