Brake Squeal is back
Old Aug 15, 2013 | 08:37 PM
traildog's Avatar
traildog
Originally Posted by texashillcountry
Did you try that brake quiet stuff on the back of the pads?
I will tomorrow.
Also when you get the calipers apart clean them good with a can of brake cleaner.
Apart? All I did was remove a couple of screws and pulled the pads out. The hardware and everything else was really clean.
Originally Posted by HarDlife
As stated, brake quiet on back of pads, make sure the pads aren't glazed (scuff em up if you have to), clean off all surfaces of any brake dust, and it probably wouldn't hurt to give them several good "power stops" after doing all the above.
I've been doing the power stops. Got the rear end squirly a couple of times..
Still squealing.
Old Aug 15, 2013 | 08:38 PM
traildog's Avatar
traildog
BTW, HarDlife found an S&S carb under that AC.......ya had me worried.....
Old Aug 15, 2013 | 09:00 PM
HarDlife's Avatar
HarDlife
Haha, that's good news. You never know, man...
Old Aug 15, 2013 | 09:08 PM
Doug S's Avatar
Doug S
Rough up the rotors and knock the glaze off the pads might help, same with that goop on the back of the pads but that is more for rattle.
I've been through a number of bikes, low and high mileage, I never have an issue with standard OEM pads and have seen many noise issues with aftermarket ones...including the expensive ones...And forget those power those power stops...
Just sayin
Ds
Old Aug 15, 2013 | 09:17 PM
traildog's Avatar
traildog
Originally Posted by Doug S
Rough up the rotors and knock the glaze off the pads might help, same with that goop on the back of the pads but that is more for rattle. Ds
Sand paper? Wire brush?
I was trying to figure out what the goop on the BACK of the pads was gonna do.........
Old Aug 15, 2013 | 09:18 PM
traildog's Avatar
traildog
BTW, the pads have Drag Specialties stamped on them.
Old Aug 15, 2013 | 09:35 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Stops the squeak from the pad rubbing on the caliper piston.
Old Aug 15, 2013 | 09:37 PM
texashillcountry
Dirt don't hurt
That's nice..
Old Aug 15, 2013 | 09:43 PM
traildog's Avatar
traildog
Angry
That's nice..
Noooo.......That's "special"
Old Aug 15, 2013 | 09:46 PM
Doug S's Avatar
Doug S
Personally, if the rotors are in good shape I'd leave them alone but if they have some grooves I'd either use some course emmory paper to scratch them or I'd replace it.
Take some 80-100 grit emmory paper and hold it tight to your workbench, run the pads back and forth keeping them flat. They hold them at a 45 degree angle and bevel both edges until you have about 1/4" beveled.
Then when the noise returns in a couple thousand miles you can get a set of OEMs and put them in...
Ds
