Brake Squeal is back
Old Aug 15, 2013 | 07:31 PM
traildog's Avatar
traildog
Default Brake Squeal is back
After beveling the pads, the squeal stopped.
It started again.......
Pads look new, rotor looks grooved but feels smooth to the touch.
What should I try next?
Old Aug 15, 2013 | 07:47 PM
Doug S's Avatar
Doug S
Sell it before it's too late...
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Did you try that brake quiet stuff on the back of the pads?
Old Aug 15, 2013 | 07:51 PM
QC's Avatar
QC
Is what I would suggest. However, while you have the pads out take a good look at the pistons, it's possible that one or two pistons is stuck in its bore and not fully pressing on the pad creating the squeal.
Old Aug 15, 2013 | 07:56 PM
texashillcountry
Dirt don't hurt
Also when you get the calipers apart clean them good with a can of brake cleaner.
Old Aug 15, 2013 | 08:06 PM
miacycles's Avatar
miacycles
Refresh my memory, front or back??? Is the hardware good?? Are the brakes dragging at all???
John
Old Aug 15, 2013 | 08:24 PM
traildog's Avatar
traildog
John
Back brake, hardware looks new, no drag.
Old Aug 15, 2013 | 08:25 PM
traildog's Avatar
traildog
Never mind.....I sold her.......
Old Aug 15, 2013 | 08:27 PM
traildog's Avatar
traildog
There's only one piston on one side of the caliper....is that wrong?
Old Aug 15, 2013 | 08:29 PM
HarDlife's Avatar
HarDlife
As stated, brake quiet on back of pads, make sure the pads aren't glazed (scuff em up if you have to), clean off all surfaces of any brake dust, and it probably wouldn't hurt to give them several good "power stops" after doing all the above.
