Broken Swing Arm
Old Aug 31, 2013 | 02:26 PM
Stiggy's Avatar
Stiggy
I did weld mine up, just some 3/4" square patches TIG welded top and bottom.
Stronger now than it was before it broke.
Old Aug 31, 2013 | 05:47 PM
machinehed's Avatar
machinehed
As stated , swing arms are usually pretty tough units and not prone to breakage unless the rider is thrashing the bike constantly or road salt is left to accumulate on the top surface of the arms and not washed off before winter storage.
If the break is a " snap off " of the unit at a particular spot , it can be welded . If the break is the result of corrosion/rot you should replace the unit .
Old Aug 31, 2013 | 11:00 PM
im's Avatar
im
Are you the original owner or is there some history on the bike?
The original factory axle tension piece is more of a lollipop style i believe for that year.
Yours looks more like a block which was an aftermarket item i believe i saw in a motorcycle magazine many years ago.
Is it possible that it had lowering blocks ?
Seen reports of this but it always equates back to lowering blocks.
Old Sep 1, 2013 | 01:16 AM
Taboo80's Avatar
Taboo80
I TIG'ed it, plated the top and bottom and added a stiffener. Seems to be fine. No one ever wrenchs on my bikes but last month while I was doing the dragon I picked up a rock in the belt and had a dealer replace it, my guess is they over tighten the axle. BTW stock, not lowered, and as for the adjusting blocks I added them a while back only due to all of the failure reports on the forums. Thanks for all your comments.
Still looking for a replacement swing arm!
Nelz
17
Jan 13, 2019 02:28 PM
E-Glidester 89
EVO
21
Jun 10, 2013 07:27 PM
basstracker05
Feb 1, 2009 11:42 PM
dynalowride
May 29, 2007 01:50 AM
wadejesu
Feb 22, 2007 07:04 AM
