Crankcase breather help
Old Sep 5, 2013 | 05:34 AM
som69's Avatar
som69
Default Crankcase breather help
I have a 94 wide glide with the big sucker filter and want to divert the crankcase output to a different system. There are many different systems out there to chose from and I would like some opinions on which way to go. thanks ...
Old Sep 5, 2013 | 08:30 AM
GraemeR's Avatar
GraemeR
not a lot of options really....Either just tuck the hose away somewhere or put a small filter on it and mount it.
Old Sep 5, 2013 | 10:43 AM
Beemervet's Avatar
Beemervet
Isn't the big sucker the one where the breathers vent directly thru the backing plate into the carby? If so you will need one closer to stock like a screaming eagle breather backing plate that vents to a hose that you can vent to a small filter or better yet under the bike.
Old Sep 5, 2013 | 11:53 AM
Tee&Vee's Avatar
Tee&Vee
i have always had good luck with just doing as Beemervet says and just plumb them underneath the bike and add a ziptie or three to the closest frame rail.
question: a properly filled engine and assuming it's within 10% of optimal tuning, how much oil should actually be coming from these breathers?
Old Sep 5, 2013 | 05:45 PM
Beemervet's Avatar
Beemervet
What comes out of the breather is really just a mist. It can be increased by filling the oil above 1/2 quart low or by running at high speeds (80 or above). Running an open hose doesn't result in oil blown everywhere, and if you have environmental concerns you are talking to the wrong guy.
Old Sep 5, 2013 | 07:09 PM
Tee&Vee's Avatar
Tee&Vee
lol
the only leaking i've done on the rg is into the primary. Forget putting all that gunk on my pistons, i vent to just behind the tranny.
Old Sep 5, 2013 | 10:35 PM
Spanners39's Avatar
Spanners39
The longer the hose the higher the pressure but the trade off is the oil doesn't land on your bike. I vent them over the rear fender if I use a hose because if you have a problem and it pukes oil out the breather, you don't end up in a ditch or as a Mack Truck hood ornament.
walster
Apr 23, 2012 07:47 PM
walster
Apr 23, 2012 05:29 PM
Fatboygooch
Mar 7, 2009 07:15 AM
leohd
Dec 21, 2007 06:18 AM
smokeygold
Dec 15, 2006 08:22 PM
