cylinder walls...???
Old Sep 12, 2013 | 03:48 PM
jsbridgew's Avatar
jsbridgew
Default cylinder walls...???
so this is what both cylinder walls look like after only about 500 miles... they're not gouged, just very lightly scored
the only conclusion i can come to is that because the cylinder studs were all virtually stripped, and wasn't getting a proper torque on them, they vibrated?
the pistons look very similar
any ideas
Old Sep 12, 2013 | 03:53 PM
bluharley's Avatar
bluharley
Not sure I'm seeing what you're seeing. Do you mean those light strips? Or is that just a light trick?
Old Sep 12, 2013 | 03:59 PM
jsbridgew's Avatar
jsbridgew
no, the dark spot running vertical in the very center of the bore...actually goes top to bottom....i suspect it looks dark because it's shiny
Old Sep 12, 2013 | 04:00 PM
Spanners39's Avatar
Spanners39
There will always be marks on the jugs if the motor has been run....remember, the pistons make the return journey 2-3,000 times a minute and over 500 miles that is 1.8 million times if cruising for 500 miles.
With a better picture I might make more of a drama of the situation but I don't often pull jugs off after 500 miles so its difficult to compare with anything.
Old Sep 12, 2013 | 04:01 PM
Spanners39's Avatar
Spanners39
Aha! Now I get you....no, that ain't pretty and you may well be right in your diagnosis.
Old Sep 12, 2013 | 04:03 PM
jsbridgew's Avatar
jsbridgew
i know.... pictures of things like this can't really tell the actual story
they're .020 over, and i hate to think i'll need a whole new bore and pistons....was hoping just a light clean up would be okay
damn
Old Sep 12, 2013 | 04:04 PM
bluharley's Avatar
bluharley
I'm lost, I don't see nothin.
Old Sep 12, 2013 | 04:05 PM
Spanners39's Avatar
Spanners39
damn
Try honing it, if the mark goes away it'll be fine. Might also have been caused because incorrect torque didn't pull the jug back into round.
Old Sep 12, 2013 | 05:00 PM
jsbridgew's Avatar
jsbridgew
will try honing it.... and yeah, i'm sure the incorrect torquing did a few pleasant things
keep you posted....thanks
Old Sep 12, 2013 | 05:45 PM
Schex's Avatar
Schex
Damn, hate when that happens.
That could have happened on initial start up if it was not heat cycled, or, more than likely, too tight of piston to wall clearance from the get-go.
Or maybe like you said about the studs, get a mic in there to find out.
Either way, looks like the piston grew too large for the cylinder.
