how much is normal?
Also bearings and so on....sticky section for Evos is lacking. I got some good info from the Dyna stickies.....but limited because of years.
I started using conventional oil (valvolene racing 20w-50) and the cylinder weeping has gone away after about 500 miles, I also run the oil a touch low (as mentioned in this thread) and my bike no longer drips from the air cleaner.
I don't run it much on the freeway, but do travel up to 60 to 65 mph for miles at a time and no issues. YD
I bought new gaskets and flapper valves and disassembled my rocker boxes. I found two issues. First, the flapper valves were hard as a rock, and no longer functioning. I noticed the new valves were a different color (likely a different material). Second, the lower-middle rocker box gasket had slipped out of position, allowing oil from the rocker box to flow into the venting chamber (when you get the rocker boxes apart, you'll see what I mean). The old neoprene gaskets are very soft, and can squeeze out from between the rocker box halves in this area, allowing oil to leak into the breather ports. The new Harley gaskets are a stiffer rubber, so I'm hoping this won't happen again.
Total job took me three hours, including removal/reinstalling the tanks. Good news, the motor drips hardly any oil now-just a tiny fraction of what she used to. and that's with running the oil at the "full" mark. I don't like running the oil level low on a Softail, since the Softail already runs a quart less oil in its system compared to the dressers (3 vs. 4). To be sure, I did try running my motor with less oil to control oil carryover. All it did for my bike was to increase oil temperature and oil consumption.
I do not want to run the oil tank at half empty either. It is not just the oil level but the fact that the oil is a heat sink. The less oil in the tank, the less there is to absorb heat and so even out the temperature spikes! At least that is how I see it with my limited knowledge!
One week after I did a regular oil change to Mobile 1 20w50 V-Twin. Last oil change done by Harley dealer just before I bought it in June. No idea which oil they used.
Very interesting, it has not spat out a drop of oil so far.
