battery
Old Oct 14, 2013 | 10:45 PM
slimpockets's Avatar
slimpockets
6th Gear
Default battery
Guys,
My 89' FLHTCU is starting to crank slow. What battery would you use to replace it? I was told the Harley battery had more CCA than the ones you find on line. I think they are like 325 CCA.
Thanks.
Old Oct 14, 2013 | 11:33 PM
Spanners39's Avatar
Spanners39
Harley is the best battery to use or a Motobatt but makes sure its a black one and not a yellow one as the yellow ones are all suspect and have been recalled.
Old Oct 15, 2013 | 04:34 AM
grbrown's Avatar
grbrown
You are right about the CCA, which these days is around 325/350 Amps with the better modern batteries. There are several brands of suitable batteries available, but be sure to buy an AGM type. They are sealed and do not have loose acid in them. Having bought it either install it and take your bike on a long ride - a tankful - or charge it overnight on a battery charger. Batteries are sold as pre-charged, but are not truly fully charged and you will get better service life if you give it a good start.
Old Oct 15, 2013 | 06:05 AM
Hackd's Avatar
Hackd
I've used batteries from a variety of sellers. My best luck has always been with the stock Harley battery. My present Harley battery is 7 years and 3 months old. Which is a record for me, having gone through batteries every two years (I finally 'fixed' the problem in 2006). IIRC, it cost around $80 back in 2006. It's currently on the workbench hooked to a Battery Tender for the winter.
I should replace it next spring, but I might 'live on the edge' and go another season with it.
Old Oct 15, 2013 | 07:34 AM
big cahuna's Avatar
big cahuna
This one claims 400 cca's. You have to check the fitment first. http://www.batterymart.com/p-Big-Cra...OhYITbuc66Rw.0
Old Oct 15, 2013 | 07:56 PM
Tee&Vee's Avatar
Tee&Vee
I had very good fortune with batteriesplus and they give you a two year warranty. Good enough for me
Old Oct 16, 2013 | 10:09 PM
Jim Kraft's Avatar
Jim Kraft
When I bought my 99 FXSTC 4 years ago the battery was 3 years old. It is now 7 years old and still going strong. It is an AGM battery that has never been on a tender and always starts right up even after sitting a couple of months in the winter. It is an Adventure Power battery, and they are available from Amazon for $80.00 last I looked. I will probably go with another one soon.
Old Oct 17, 2013 | 02:03 AM
Homeward Bound's Avatar
Homeward Bound
Any recommendations for a modern battery that actually fits the space in the frame for them? From memory, about 8" and a bit.
Many of the new ones, due to improvements in technology, are considerably smaller and require padding up.
Are the like of the Odyssey Batteries worth paying the extra for.
Mottobatt do a range of sizes but not as many as OEM manufacturers. I don't have an original battery to measure up. It'd be nice and practical to have one that at least fitted height and depth wise to hold it better.
c50plus
Apr 16, 2015 11:47 PM
greg3131
Jan 7, 2013 05:15 AM
jlfabian
Aug 29, 2012 10:27 AM
garett742
May 9, 2012 07:50 PM
StreetGlider57
Oct 19, 2010 07:41 AM
