It says right there in the shop manual to check all the fasteners for tightness at every oil change. Bet you didn't check that one, did you? So, YOUR FAULT.
Use different len's than you, but learned, after about 6 months, after I bought the bike, to keep extra lens at home. Mine have 3 tangs , molded into the back of the lens, that snap into the housing, & for some reason one of the tangs will break off & won't be long, if I dont catch it, will pop out. I check them now, every so often. Vibration is all I can figure out , what causes the tang to break off.
Ride Safe,
Harold
When I bought my bike it had a shorter light bar on it that 'looked cool' but to my mind didn't really put the turn signals in a clearly noticeable place. I decided that since I didn't want to get run over from behind by some SUV driver thinking I was turning left when I was turning right that I would get a stock length bar which makes it more obvious.
