Coil replacement short cut
Old Nov 26, 2013 | 06:19 PM
RCermak's Avatar
RCermak
Default Coil replacement short cut
Do I have to completely drain and remove the Gas tank to replace the coil on my 97' Ultra classic ? Is it possible to just prop it up and get at it?
Old Nov 26, 2013 | 09:08 PM
Jasper86's Avatar
Jasper86
2x4 or 2" pvc pipe under the tank will get it up enough. a *long* extension with a ball end hex helps a *lot*
Old Nov 27, 2013 | 04:41 AM
Hackd's Avatar
Hackd
As long as the crossover tube gives you enough room you can. Otherwise, just drain the tank, disconnect the crossover tube and fuel line from petcock, and remove the tank.
Old Nov 27, 2013 | 04:48 AM
grbrown's Avatar
grbrown
Thumbs up
That's a pain if you just filled the tank, obviously! Having got as far as above, buy yourself a quick release connector, which speeds up the process and avoids the need in future to drain the gas off.
Old Nov 27, 2013 | 10:57 AM
Beemervet's Avatar
Beemervet
I can't begin to tell you how great it is to have one of those.
Old Nov 27, 2013 | 11:46 AM
falconbrother's Avatar
falconbrother
that's a pain if you just filled the tank, obviously! Having got as far as above, buy yourself a quick release connector, which speeds up the process and avoids the need in future to drain the gas off.
like!!
Old Nov 28, 2013 | 08:50 AM
RCermak's Avatar
RCermak
Default Hole in the Garage
My wife wants a boat and I told her that it was just a hole in the water where you throw all of your money. She is now giving me an issue with having a hole in the garage. I just went for a ride..
UltraBrian
Jul 8, 2016 12:50 AM
YtseJam
Dec 1, 2013 10:19 PM
92oldskoolxlh
Feb 28, 2012 08:38 AM
Gman in NC
Jan 27, 2010 02:54 PM
dchoran
Apr 16, 2008 07:20 PM
