Lower Legs??
Old Jan 17, 2014 | 08:16 AM
01fxdxt's Avatar
01fxdxt
The damper rod on bottom of fork is probably(should be) locktited.Use a hand held impact driver with a non-Chinese allen bit.That is the hardest thing you should encounter.Follow manual.You will need proper snap ring tool also for large ring above seal.
Old Jan 17, 2014 | 11:53 PM
92Fatty's Avatar
92Fatty
I did mine. I picked a used set and took them to a local shop to chrome them. I R&Red myself. As said mine had a 6mm allen for the damper rod. I used a hand impact for removal. I took the chromed legs\sliders to the harley shop and they installed the top seals for me. I also put in progressive lowering springs at the same time.
Old Jan 26, 2014 | 07:43 AM
fatty 95's Avatar
fatty 95
i just finished mine. they were original 1995 and were in bad shape. i took the wheel and the fender off. makes it easier. 2 days and 2 six packs later its done and worth it. now waiting for ball bearing conversion kit and i'm back in the saddle
Sklplmr
15
Apr 6, 2015 08:10 PM
billzflhtc
EVO
Feb 5, 2015 12:57 PM
Steve Jenkins
Apr 29, 2013 03:55 PM
Karsten
Apr 6, 2012 09:05 PM
antman27
Mar 17, 2011 05:49 PM
