What is this?
Old Jan 18, 2014 | 09:23 PM
misfitJason's Avatar
misfitJason
And if it ever comes loose and gets sucked into your carb. Baaammmmoooo
That link shows them at 90 bucks. Man is that expensive. If it works though then I guess it is worth it
Old Jan 18, 2014 | 11:54 PM
brad75raiders's Avatar
brad75raiders
Ebay item says SIFTON HOP UP KIT SUPER E
Old Jan 19, 2014 | 08:01 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Fount it.
Thank you.
Old Jan 19, 2014 | 04:06 PM
billzflhtc's Avatar
billzflhtc
Default What is this
Don't know who makes it but it looks like a variation, copy, of the"boosters " on a holley 4barrel carb. On them, they work by vacuum, the vacuum pulls extra air/fuel through the jets etc as needed. they have holes all along the bottome edge of the circle to spray the fuel out
Old Jan 19, 2014 | 04:20 PM
Jasper86's Avatar
Jasper86
DaVinci "FirePower" booster. they've been using them on S&S carbs for big-hp builds...apparently they work VERY well, but typically only in conjunction with venturi boring (used partially to help after boring out the venturi in S&S carbs)
you usually dont see them in Mikuni's because they aren't needed (variable venturi by design)
http://www.ebay.com/itm/290445579002...84.m1423.l2649
(the purple kit is the "big boy" for G/D carbs, will likely end up with one in my G carb after I send it to XXX for the Taz treatment)
Old Jan 19, 2014 | 05:40 PM
texashillcountry
Dirt don't hurt
A friend of mine bought an '88 FXR with a 113" motor and a S&S G that had that in it.
I think I'm gonna put one in my E carb.
Old Jan 19, 2014 | 05:53 PM
traildog's Avatar
traildog
I don't know what it is, but it's DIRTY........... ;'0
Crimson King
Jul 15, 2017 04:20 PM
doctorgoo
Shovelhead
Aug 9, 2011 08:22 PM
magnum629c
Jan 29, 2010 04:56 AM
GPHDXLC
Exhaust System Topics
Nov 6, 2008 05:59 AM
HDF Tech
Engine Mechanical Topics
Jun 26, 2005 12:12 PM
