Hitachi starter question.
Old Jan 28, 2014 | 01:27 PM
Ken Oaff's Avatar
Ken Oaff
Originally Posted by falconbrother
How do you clean the commutator? Do you use contact or MAP/mas air flow sensor cleaner?
fine emery / sand paper works - just clean all the crap off before you reassemble it
Old Jan 28, 2014 | 01:29 PM
Ken Oaff's Avatar
Ken Oaff
Originally Posted by johnjzjz
all ***** sells a Hi torque unit but its not cheap
but it works and its money well spent, rebuilt my shovel and it turned the motor over, the hitachi wouldn't neither would the thunder fire unit I bought
Old Jan 28, 2014 | 02:49 PM
megawatt's Avatar
megawatt
If the commutator is in bad shape it might still be repaired by chucking the rotor up in a lathe and taking a cut on it. Then clean the gap between the commutator sections with a hacksaw blade or a thin file.
I suppose some folks have used drill motors or drill presses to spin the rotor while cleaning up the commutator with strips of emery cloth. I am not recommending it, but I'd bet it's been done.
I think the Hitachi starter is a good unit, well worth trying to repair.
Old Jan 28, 2014 | 08:37 PM
Hopper's Avatar
Hopper
If the copper is not too worn down on the commutator, a good scrub with a green Scotchbrite pad until it is a nice shiney copper color is all it needs.
Emery paper and sand paper can leave abrasive particles embedded in the copper, which can lead to rapid brush wear.
But lots of guys use emery paper and seem to find it ok. No need to spin the rotor to use it, just rub by hand. All you are doing is removing a thin layer of corrosion.
Old Jan 29, 2014 | 06:09 AM
RaSh's Avatar
RaSh
Thanks for the advice all.
Doesn't appear that this is going to be a winter that I drive in much, and it's currently too cold to work in the garage, so I'll let my ride sleep on the tender for a bit.
Appears that a general connector clean-up will be a good start, then run it a bit and see if a little more TLC to my factory starter is called for.
Again, thanks, I appreciate real world advice.
irydasteelhorse
EVO
Feb 22, 2014 10:00 PM
eglideic
Shovelhead
17
Nov 25, 2013 12:22 AM
goliath1
Dec 20, 2012 05:09 PM
jason8251
Electrical/Lighting/Alarm
Jul 27, 2011 03:23 PM
lebert
Aug 7, 2010 07:03 AM
