Rear axle nut question
Old Feb 10, 2014 | 04:51 PM
falconbrother's Avatar
falconbrother
Default Rear axle nut question
I noticed on my 1988 FLHTC that the rear axle nut is not castelated. It is just a big lock nut and I don't see that the axle was ever drilled for a castle nut. Is this the way these models were? I sure would feel better with a castle nut and a cotter key.
Old Feb 10, 2014 | 05:09 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
According to my parts manual, the `88 models used:
Axle 41110-79A (this axle is drilled for a cotter pin)
Hex nut P/N 7986
Washer P/N 6655
Lock washer P/N 7022
They changed the axle nut setup for `89:
Axle 41110-79A
Castle nut P/N 7987
Spacer 5756
Get the axle (same for many years), nut and spacer for `89 and you will be good to go.
Old Feb 10, 2014 | 06:16 PM
johnjzjz's Avatar
johnjzjz
your bike uses a nut, lock washer than a flat washer, and it does not come loose if you torque it in place -- i have installed a NY lock in place of the nut and lock washer, and if you use a new one each time the ( ny lock ) it will never fall off or come loose -- johnjzjz
Old Feb 10, 2014 | 07:25 PM
GraemeR's Avatar
GraemeR
Mine is the same...just a flat washer, lock washer and normal nut.
At 60lbs of clamping pressure it has not come loose in 25 years. I will swap to a castellated nut one day as its a requirement for racing, but thats the only reason I'll be doing it.
Old Feb 10, 2014 | 07:44 PM
falconbrother
I thought about drilling the axle and getting a castle nut. I usually add a drop (or two) of blue Locktite to the threads when I reinstall the nut. It's not come lose since I've had it but, it doesn't seem like the best design I've ever seen.
Old Feb 11, 2014 | 01:14 AM
Ken Oaff's Avatar
Ken Oaff
250,000 kms and its yet to come loose
castelated nut is an engineering overkill and its not necessary
sweet07
Mar 10, 2020 02:01 PM
harley_jeff
Jun 12, 2016 12:22 AM
DarkManC
Mar 5, 2014 08:31 PM
RazorFXDB
Apr 16, 2008 06:10 PM
