Radial tire plug
I hope it helps with the nails.
I got left on the side of the read for a couple of hours due to a nail in the rear tire.
Hence the change to mag wheels.
Thinking I need to invest in the stuff to do that.
I've gone 1000's of miles on tires I plugged myself. Just a nail or similar size hole with no tearing, in the tread, doesn't bother me. Tubes bother me. I put tubes in three wheels last year, only because they were spoke wheels, but I did them myself, do not trust anyone else to be as finicky and ridiculously cautious putting them in as I am (I've never torn a tube installing it, either). If a tire is bad enough it can't be plugged, I wouldn't put a tube in it either, time to replace. If I was going on a long (days) ride, I'd replace a plugged tire with a new one, but save the plugged tire for future use till it got too old (probably around 5 years from manufacture date). Haven't had a flat in over 10 years, but that's how I did it, and would again.
I don't recall any roadside punctures on that bike, although I'm sure I had them. On other bikes a puncture was a routine repair and best done by changing tube, rather than patching.
As for those who think tubeless are better, if the tyre beads come off the rim you are stuffed! A tube will fix that, as the only roadside means of getting the beads back on. It's not much fun being trailered because of a 'flat'!
