James or Cometic gaskets
Old Feb 27, 2014 | 07:30 PM
johnjzjz's Avatar
johnjzjz
Originally Posted by tmanbuckhunter
I would have used the tin moco ones but I already had the rear rocker box on and torqued down... maybe one day when I get around to it I'll replace them, but not until they start leaking.
during the transision between paper and the tin we used up all the old stock and being a dealer i had piles of them we buy in lots of 100 each piece -- some came back 6 months / a year later some didnot - but that was the time frame for leaks - jz
Old Feb 27, 2014 | 07:32 PM
tmanbuckhunter's Avatar
tmanbuckhunter
Yeah... we'll see how long these go.. I'm not too concerned. If they last a year I'll be happy. I've done torn this thing down one too many times since the rebuild to just replace something that's working fine right now.
Old Feb 28, 2014 | 06:51 AM
Tee&Vee's Avatar
Tee&Vee
either
Old Mar 2, 2014 | 08:42 AM
gsxrboy96's Avatar
gsxrboy96
Cometic, I won't use anything else ,
Old Mar 2, 2014 | 11:29 AM
1/2crazedbikr's Avatar
1/2crazedbikr
I used Cometic on my rocker boxes a couple of years ago and have even pulled them off a couple of times. Had to just loosen and crack open the lower ones when I replaced the cam. Then buttoned her back up with the same gaskets.
Seem to be holding just fine.
Old Mar 3, 2014 | 06:54 PM
rivercityslim's Avatar
rivercityslim
Full set of Cometic on mine...
Old Jan 30, 2024 | 01:50 AM
DarthJohn's Avatar
DarthJohn
Cometic Multi-Layer Steel (MLS) head gaskets go on dry because they are coated with a sealant. Each MLS head gasket is coated with a . 001" thick Viton rubber that is bonded to the outer stainless steel layers. Adding an additional sealer can hinder the performance of an MLS head gasket.
Keithhu
Jul 15, 2017 09:53 PM
ballbreaker69
Jun 17, 2017 07:07 PM
xbox
Dec 16, 2014 10:35 AM
harleylay
Mar 9, 2011 01:00 PM
WhiteGoldSG
Jul 31, 2010 04:33 PM
