Uneven Brake Pad Wear
Old Feb 27, 2014 | 07:05 PM
traildog's Avatar
traildog
Default Uneven Brake Pad Wear
Good Evening....Love and Peace to you All (well, most of you anyway).
What's up with this?
Front Brake Pads.
Old Feb 27, 2014 | 07:07 PM
tmanbuckhunter's Avatar
tmanbuckhunter
I noticed my pads weren't wearing correctly... turned out one of the calipers up front was stuck badly, and the rear wasn't far away from being toast. I ordered rebuild kits from J&P cycles and re-built them all... works like a charm now.
Old Feb 27, 2014 | 07:10 PM
traildog's Avatar
traildog
Funny thing is, the pad with the least wear is the one against the piston.....
Old Feb 27, 2014 | 07:12 PM
Kees's Avatar
Kees
Front Brake Pads.
It's no different to the uneven wear on your rear tyre
Old Feb 27, 2014 | 07:14 PM
traildog's Avatar
traildog
Does that mean it's normal wear?
Old Feb 27, 2014 | 07:15 PM
Kees's Avatar
Kees
Yep for your riding style it is ... LOL
Old Feb 27, 2014 | 07:16 PM
46knuck's Avatar
46knuck
Normal for the most part but that seen here seems a but much for sure.
Old Feb 27, 2014 | 07:18 PM
Kees's Avatar
Kees
BTW...there's nothing normal about you TD.....sparkling clean seaforming hunkie doodle diddly ding ding !!!
Old Feb 27, 2014 | 07:20 PM
tmanbuckhunter
I'm still not quite sure, but if you're that far into a pad change you might as well rebuild and do a fluid change. Doesn't take long, although I'm sure you know very well.
dyna105's Avatar
dyna105
That much difference in wear I would think it was not normal. I would check the caliper. Looks like the piston may be sticking.
