Help with rear brake
Old Apr 8, 2014 | 06:35 PM
Maxdog2's Avatar
Maxdog2
Default Help with rear brake
I went to install a new set of pads today and stripped one of the pin bolts. Item #11 in the service manual. Torque is 15-20 lb. ft. so maybe maybe corrosion or dissimilar metals. Any suggestions on how to get it out? I have sprayed liquid wrench on it and may try some needle nose vise grips. Simple job turns to %^&&%%(#@!
Old Apr 8, 2014 | 06:38 PM
Spanners39's Avatar
Spanners39
Firstly I wouldn't use a torque wrench on those bolts...secondly, if its stripped and turning but not coming out, I would apply some leverage or pull on the bolt head as I turned it out.
Old Apr 8, 2014 | 07:22 PM
Maxdog2's Avatar
Maxdog2
Not sure what the previous owner used, but may have used locktite. It is a star head type bolt and that is what stripped. The bolt is not turning and is stuck in the caliper.
Old Apr 8, 2014 | 07:24 PM
Spanners39's Avatar
Spanners39
The head is stripped you mean?..not the thread?
In that case, get a nut that you can bash onto the head, weld it in place and wind it out with a socket
Old Apr 8, 2014 | 07:32 PM
Maxdog2's Avatar
Maxdog2
I have a new welder, but no gas. Guess I will drill it out. Thanks for you suggestions.
Old Apr 8, 2014 | 07:34 PM
traildog's Avatar
traildog
https://www.buyspeedout.com/?MID=5358391
Old Apr 8, 2014 | 07:36 PM
traildog's Avatar
traildog
Old Apr 8, 2014 | 08:00 PM
Turret_plug's Avatar
Turret_plug
Just went through this on Saturday..... Torched it, the. Used vise grips..... Turned out after a few tires with the propane torch! Replaced it with a speed bleeder..... Pure motorcycle magic!
Old Apr 8, 2014 | 08:06 PM
Maxdog2's Avatar
Maxdog2
I have a bottle and will give it a try. Not the same bolt, but should work. thanks
Old Apr 8, 2014 | 08:07 PM
Maxdog2's Avatar
Maxdog2
Originally Posted by traildog
Looks like a good option. Going to try some heat and see if it will budge. Thanks!
