How do i check the compensator
Old May 6, 2014 | 08:26 PM
HarDlife's Avatar
HarDlife
Originally Posted by soft 02
The bolt will need to be removed and red lock tite re applied to do it correctly. If you just tighten it it will break the lock tite free.
I would just check with your tw set @ 150. If it clicks without the NUT moving AT ALL then your okay. If the nut moves any amount, you will have to remove it, clean threads of nut and shaft, add 2-3 drops of red loctite, and torque to a minimum of 150# (I would tighten it a smidge past that). Mark the position of the nut so you can tell for sure if it moves or not.
Old May 6, 2014 | 08:33 PM
HarDlife's Avatar
HarDlife
You removed it. Clean threads, apply loctite, reinstall and torque to specs.
Why did you take it off, were you having a problem?
Old May 7, 2014 | 03:57 AM
br549A1's Avatar
br549A1
I got it back on, adjusted the clutch and chain while I had it apart. I wanted to check it make sure it was good and once I had it off I don't think you can visually inspect it. I know it's tight now at 165#. Can't beat the free tool rental, I knew they had it, but thought it was only special tools like bearing pullers for cars.
Here's the odd thing. After I got it all back together, before loosening the chain adjuster, there was way more slack in the chain than there was when I started. Nothing moved that I can see and I don't believe that the chain could develop slack simply from tightening the comp nut. Is it possible something was misaligned and tightend up incorrectly prior to me disassembling it?
Old May 7, 2014 | 08:52 AM
92Fatty's Avatar
92Fatty
You may have just rotated the chain around some. The chain will have different levels of play at different locations. Rotate the chain all the way around noting the loosest area and adjust there. Also make sure you clean the threads on that comp sprocket bolt and apply a couple drops of red loctite.
Old May 7, 2014 | 09:57 AM
br549A1's Avatar
br549A1
I definitely did that. It was looser after and I rotated it around about 5 times it never got tighter until I adjusted the shoe. There's no way that shoe moved either it was still tight. Doesn't make any sense to me at all. I know your thinking it's not possible but it happened somehow.
Old May 7, 2014 | 10:31 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
How did you lock your gears when you got the compensator nut off?
Did you use a locking bar or just jam something between the chain and the sprocket gear?
I may be completely wrong but the first time I took mine apart I started to jam something (block of wood) between the chain and the sprocket but I stopped fairly quickly because I didn't like putting that much tension to one point of the chain.
Old May 7, 2014 | 10:40 AM
br549A1's Avatar
br549A1
I used shop towels, terry cloth? On both ends so it was stopped both ways. They were thicker than normal shop rags more like bathroom hand towels.
Old May 7, 2014 | 10:52 AM
texashillcountry
Dirt don't hurt
If you can adjust the chain tension to within spec then I would do that and not worry about it.
The next time you have to take off the chain check it to see if it is too stretched.
If you can't adjust the chain to spec then go ahead and replace it.
In the future I would use a lock bar between the sprockets so that you don't put any extra tension on the chain. JMO
Old May 7, 2014 | 11:18 AM
br549A1's Avatar
br549A1
I think it's fine too I just couldn't understand what could change so much from tightening it. Lock bar probably would have been better or I should have ordered the tool. I didn't plan to do it just had the time and wanted to change the fluid again so figured I should knock it all out in one night.
Old May 7, 2014 | 11:25 AM
Beemervet's Avatar
Beemervet
Man, it sounds like you should follow "If it ain't broke, don't fix it".
