A shop that rebores engines has a procedure that they follow and they are quite aware of the importance of cleaning out the stuff that results from the machining process etc. In my opinion your cylinders are ok and your comp. test seems to prove this as your readings for both cyls. are equal and normal.
In my experience the psi. difference you see between hot/normal and hot/wet is ok. for a motor that has not been " correctly " run in yet.
You said you installed a aftermarket " breather ? " and i suggest you check that for proper operation. Also check the pushrod tubes to ensure you have replaced the old o/rings etc. etc.
I suspect that you have a simple oil leak at the pushrod tubes otherwise there would be oil spewing out everywhere.
Relax and let us know what you find .
yes your right a shop that bores cylinders does know how to clean them properly. but unless there installing them they don't clean them. that's the builders job even S&S tells you to clean there cylinders properly before you install.
that's why I say this is a big problem. first time engine builders assume they are clean and find out the hard way they were not.
also a stock evo with a N grind cam and 12.9cc domes on the pistons will produce 185 to 190 ccp. but im guessing on his cam
so his compression is low. that's why I said to do a leakdown test to see how much is leaking past the rings.
I performed cylinders leak down test and discovered the following:
Front cylinder had strong airflow coming from the carb and rear cylinder had strong airflow coming from exhaust. I backed off the adjustment on all four adjustable push rods to ensure all valves were fully closed.
Afterwards, test results of front cylinder at TDC is 25%. Rear cylinder at TDC is 22%. From what I understand, I newly rebuilt cylinder should be less than 20%?
Also, during testing of both cylinders, I could hears a slight hissing sound coming from the timing plug hole (plug was removed). Is this normal?
fxrstew
dont sweat the 2 or 3 percent difference - each directions i have read about doing a leakdown have never said anything about the compressors line pressure < and that will make a difference in the percentage loss overall
if the motor is not seated in yet like these numbers suggest and the loss in the timing plug hole is heard ( the pressure is passing the rings ) - you need to drive it a 1000 miles maybe and keep the RPMs under 3000 - some machine shops use a grit stone that takes longer than others
if you cant get the push rods to stop weaping you can use another top thick o ring in the center as that will make the tube very tight and it will seal it up -
fxrstew
that is close to normal for a new engine. do like john said put a 1000 easy miles on it and check it again. the numbers I like to see 5 to 10 percent after break in. my new engine has about 45 min on it so its not broke in yet.
and I have 18% front 16% rear. and I have 2.6 cfm flowing out the breather.
after break in the cfm will drop to around 1.9
drive it like a human for the time being --
you are right most testers wont tell you this its a big secret. I was told by a very well know builder years ago use 120psi.
No air should be coming through intake and exhaust ports.
you are correct about loss at the valves --
but his discription was at the timing PLUG an audible sound coming from the plug hole
the Harley V Twin relies on a cylinder loss ( piston ring seal or lack of ) to be able to then use it ( high pressure air ) to lube the cam chest and all its workings Via the breather valve as it is timed to take advantage of the event -
yes your right a shop that bores cylinders does know how to clean them properly. but unless there installing them they don't clean them. that's the builders job even S&S tells you to clean there cylinders properly before you install..
I have built a bunch of inline 4s and that has been my experience with APE, you have to clean the cylinders yourself.
I performed cylinders leak down test and discovered the following: Front cylinder had strong airflow coming from the carb and rear cylinder had strong airflow coming from exhaust. I backed off the adjustment on all four adjustable push rods to ensure all valves were fully closed.
but his discription was at the timing PLUG an audible sound coming from the plug holejz
