Excessive Engine Pressure
Old May 8, 2014 | 06:08 PM
fxrstew's Avatar
fxrstew
1st Gear
Question Excessive Engine Pressure
I have a 1993 HD FXR with breathable heads. Recently, I rebuilt the motor and bored cylinders out to .020 and installed Wiseco 10:1 pistons. Also, installed S&S breather, Harley tappets, Harley tappet guides, and Harley push rod covers.
Currently, having problems with oil leaking through lower push rod covers. I suspect that motor is creating to much pressure.
On the 1993 engine case, is there vent plug that I can remove to install a hose fitting to help relieve pressure?
I own a Harley shop manual for that year/model, but I cannot find any mention of a vent plug?
Hoping for an easy fix!
Thanks
Old May 8, 2014 | 07:02 PM
johnjzjz's Avatar
johnjzjz
your rings have not sealed or you have driven it to fast too soon and the cylinder walls are scrached causing the ring seal to go away
i have seen it come back but most times it has to come apart again -
try driving it with engine speed no faster than 2500 for a couple hundred miles
Old May 8, 2014 | 08:03 PM
D_gyver's Avatar
D_gyver
ive seen this a lot. a small portion are from improper break in. and the biggest problem they didn't wash the cylinders properly after boring. that hone grit will ruin a new cylinder if not cleaned out
Old May 9, 2014 | 01:49 PM
HarDlife's Avatar
HarDlife
How do you have your breather system set up? Might want to do some compression/leak down tests.
Old May 9, 2014 | 03:13 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I just went through exactly the same thing. I found oil all down the side of my bike in alarming amounts.
I took it all back apart again and the only thing I could find wrong was that I had the 2 longer bolts in the cam chest backwards.
I have no idea why but it doesn't leak anymore.
Old May 10, 2014 | 07:20 AM
Uncle G.'s Avatar
Uncle G.
You don't say what you are using for pushrods, but if you are using adjustable or "quick install" pushrods, it is possible to have a pushrod that is "bent" (actually brazed together crooked). As adjustable pushrods are larger diameter than the stock pushrods, it doesn't take much eccentricity for the pushrod to be able to hit the cover. If this happens, as the pushrod rotates during running, it can actually "rock" the pushrod cover enough to break the seal, usually at the lower o-ring. This can cause an intermittent leak.
I know this from experience.
Old May 10, 2014 | 07:22 AM
Uncle G.'s Avatar
Uncle G.
Don't feel bad, Tex. I've done the exact same thing.
Old May 11, 2014 | 01:46 PM
fxrstew's Avatar
fxrstew
1st Gear
With the motor hot and the throttle wide open, I performed a compression test on each cylinders. Both cylinders measured at 140 psi. Afterwards, I poured a small amount of oil in each spark plug hole, and performed another compression test. Each cylinder peaked at about 185 psi. I think I do have leaking piston rings.
Old May 11, 2014 | 05:59 PM
D_gyver's Avatar
D_gyver
that's not really gonna tell you what you need to know. you need to do a leak down test see how much you are losing past the rings.
Old May 13, 2014 | 05:36 PM
machinehed's Avatar
machinehed
Default Dont panic yet !
A shop that rebores engines has a procedure that they follow and they are quite aware of the importance of cleaning out the stuff that results from the machining process etc. In my opinion your cylinders are ok and your comp. test seems to prove this as your readings for both cyls. are equal and normal.
In my experience the psi. difference you see between hot/normal and hot/wet is ok. for a motor that has not been " correctly " run in yet.
You said you installed a aftermarket " breather ? " and i suggest you check that for proper operation. Also check the pushrod tubes to ensure you have replaced the old o/rings etc. etc.
I suspect that you have a simple oil leak at the pushrod tubes otherwise there would be oil spewing out everywhere.
Relax and let us know what you find .
