Help with 1990 EVO
Old May 12, 2014 | 12:57 PM
twospeed's Avatar
twospeed
Default Help with 1990 EVO
Need some advise, have a 1990 soft tail, 38K miles. I spotted a crack on the front of the rear tappet block near the screw hole running top to bottom. So I decided to replace before something really bad happens. Murphy is a sneaky fellow.
Bought chrome lifter blocks, Ultima lifters, Untima quick change push rods.
New Torrington B138.
Bike is fast, in my opinion.
Bike has an idle similar to a B gas coupe from the 60s with an isky cam and headers. To say the idle is horrible is kind!
Opened the gear case. Cut the push rods with a bolt cutters.
Andrews EV-3 inside. Lifters look brand new, roller wheels feel solid no play no visible wear.
Came looks good, some blue discoloration just upwards for the base of the cam on both sides.
Found a Torrington B128 in side marked Torrington .
Questions: Is there any benefit to go to an EV-27 over the EV3 Would the performance gain justify the expense, moneys tight right now.
Should I pull the Torrington out and replace with a Torrington that’s not even a Torrington any more?
Bike is an FXSTC that is going Vicla style .
It had an S&S Carb and Cleaner with Vance and Hines long shots. I am the third owner. The second owner bought it in 2005, the bike had these mods, like I said runs very strong,
Not interested in bragging rights to anything, even when it comes time for a rebuild
Only going .010 over, all new bearings and a balance of the rotating assembly.
Like I said I’m not looking to get there first, as long as I get there.
No I’m not to old for this, Have raced hot rods and corvettes. Harley s are a state of being. End of story.
Your input will be appreciated, Twospeed
Old May 12, 2014 | 12:59 PM
twospeed's Avatar
twospeed
By the performance it may even had milled heads
Old May 12, 2014 | 01:09 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
If it were me I would change the bearing every time I went in that far.
Old May 12, 2014 | 01:19 PM
aces&8s's Avatar
aces&8s
Iv had the EV3 before and it ran great. Id just put everything back with new bearings.
Old May 12, 2014 | 01:30 PM
twospeed's Avatar
twospeed
I appreciate the reply's
Old May 12, 2014 | 03:25 PM
Dr.Hess's Avatar
Dr.Hess
I'd just put the new lifter blocks and pushrods in and be done with it.
Old May 12, 2014 | 08:34 PM
billib1954's Avatar
billib1954
I learned something the other day. Lifter block alignment tool is needed to center lifter block. Just in case you didn't know. It is a tapered pin that screws into one of the holes while you install the other three screws.
Old May 12, 2014 | 08:39 PM
johnjzjz's Avatar
johnjzjz
the intended purpose of the tool is to align the oil hole so the center bolt holes are used next to the oil hole its self
Old May 12, 2014 | 09:11 PM
Schex's Avatar
Schex
Hey twospeed, post up a picture of speed #1(stop), and a video of speed #2(WFO)
Old May 13, 2014 | 01:06 PM
twospeed's Avatar
twospeed
Hey Schex3x
I have no idea what you are talking about?
Depending on the day , time, and situation,
Slow and Slower, or Fast and Faster, never know how its going to turn out?
Been like that since 1967 so has the name
