Help with 1990 EVO
Old May 16, 2014 | 07:05 PM
machinehed's Avatar
machinehed
Default cracked tappet bock.
Originally Posted by twospeed
Need some advise, have a 1990 soft tail, 38K miles. I spotted a crack on the front of the rear tappet block near the screw hole running top to bottom. So I decided to replace before something really bad happens. Murphy is a sneaky fellow.
Bought chrome lifter blocks, Ultima lifters, Untima quick change push rods.
New Torrington B138.
Bike is fast, in my opinion.
Bike has an idle similar to a B gas coupe from the 60s with an isky cam and headers. To say the idle is horrible is kind!
Opened the gear case. Cut the push rods with a bolt cutters.
Andrews EV-3 inside. Lifters look brand new, roller wheels feel solid no play no visible wear.
Came looks good, some blue discoloration just upwards for the base of the cam on both sides.
Found a Torrington B128 in side marked Torrington .
Questions: Is there any benefit to go to an EV-27 over the EV3 Would the performance gain justify the expense, moneys tight right now.
Should I pull the Torrington out and replace with a Torrington that’s not even a Torrington any more?
Bike is an FXSTC that is going Vicla style .
It had an S&S Carb and Cleaner with Vance and Hines long shots. I am the third owner. The second owner bought it in 2005, the bike had these mods, like I said runs very strong,
Not interested in bragging rights to anything, even when it comes time for a rebuild
Only going .010 over, all new bearings and a balance of the rotating assembly.
Like I said I’m not looking to get there first, as long as I get there.
No I’m not to old for this, Have raced hot rods and corvettes. Harley s are a state of being. End of story.
Your input will be appreciated, Twospeed
Not sure about the advantigis over a Ev3 and Ev27 as i understand they are quite similar?? Check the specs. to know for sure .
Your lumpy idle is probably from the carb. Check to assure the carb. is calibrated to your current exhaust system . Harley wants $20.00 each for the lifter block alighnment screws .! You can do as i did and purchase 2 1/4 /20 bevel head machine screws to do the same thing for $ 2.00.
Note : the lifter blocks must be alighned correctly and i suspect that the po didnt do this .
Diesel68mc
EVO
May 2, 2015 10:21 PM
magnashopper
EVO
14
Feb 6, 2014 08:27 AM
machinehed
EVO
18
Oct 22, 2012 05:53 PM
HarleyX89
EVO
40
Feb 7, 2012 05:14 PM
Ugly's 98HD
EVO
Sep 30, 2009 08:55 AM
