I've also been told that the Mikuni will make the bike feel more responsive as well, any thoughts on this??
[/quote]
Yes, it gives a more immediate response than the CV, in my experience. I had a Mikuni and swapped it for a CV on an otherwise stock motor (with pipes and aircleaner). But...
Doug S "For the price of the Mikumi you can do cam, cam bearing and lifters, rejet the CV and live happily ever after"
I would agree with Doug S if I hadn't already had the Mikuni.
The SE ignition module made a big difference on my bike over the stock one. If I had to GUESS, I would GUESS that the difference in the part numbers you mention, with one being for a FLHT and the other not, are the length of the wires running down to the pickup. The FLHT's of the era needed a longer wire to the plug than the other bikes. The MoCo actually sold a harness extender to put the shorter wired SE modules on a FLHT (off road use only, of course, with your full dress touring bike.)
My first guess would be that there may be a connector difference.. My '94 WG has a 7 pin connector on the module, the newer ones came with 8 pin's.. I dont remember the breakoff, but that's something to keep in mind..
You're not far away from Matts Machine Shop, near Cardiff. Matt supplied and installed my S&S 107" engine and I can heartily recommend him. He also has a shop in England which may be closer to you, but I'm not sure exactly where. He's 250 miles from me, so on your doorstep!
Reason: Added link.
You're not far away from Matts Machine Shop, near Cardiff. Matt supplied and installed my S&S 107" engine and I can heartily recommend him. He also has a shop in England which may be closer to you, but I'm nor sure exactly where. He's 250 miles from me, so on your doorstep!
Graham - your a supper star, cheers mate!
I don't move too quick with these things, but I'll let you know how I get on.
