intermitten starting issue....
Old Jun 1, 2014 | 06:56 AM
watindes's Avatar
watindes
Default intermitten starting issue....
Hey all I have an occasional starting problem. What I have done:
New outer ring gear assembly ( it was cracked)
Dreaded click modification, known good battery
What my 1986 flhtc does is if I make a short hop to the store ( after warmed up) is if I try to start it, it sounds like the starter is not kicking out I was hoping the ring gear assembly being cracked was the issue. It had to be repaired anyway. If she is warm, sitting in the sun ect. Or a nice ride it starts ok.
What should I look at next?
Old Jun 1, 2014 | 07:28 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What do you mean by not kicking out?
Does the starter sound like it is spinning, but the engine is not cranking?
If so, suspect the starter drive unit.
Old Jun 1, 2014 | 07:54 AM
RANGER73's Avatar
RANGER73
Starter relay is probably going. Replace it, 10.00. If that does it, then get a starter solenoid push button.
Old Jun 1, 2014 | 11:18 AM
Dan89FLSTC's Avatar
Dan89FLSTC
`86 is a different starter configuration than modern (`89 and later) systems. No push button band-aid for this.
We need a more accurate description of the problem.
Gordon65
Apr 13, 2017 07:50 AM
falconbrother
EVO
11
May 20, 2016 06:18 PM
lebert
Aug 7, 2010 07:03 AM
CHUOT
Ironhead
Jul 27, 2008 04:02 PM
bob
Mar 27, 2005 02:09 AM
