Starting Dad's Evo
He will never ride again due to health, but I think he wants to see it-hear it.
Maybe he wants to sell it. Hard to tell sometimes.
I am going to start with a new battery. Tires will probably need replaced. Air cleaner will need blown out or replaced. Hopefully the tires are good enough to get me 35 miles. Did they use tubes in 1994?
How would you advise getting rid of old residue left by old gas? This is probably my biggest worry as far as repair. My thought is to drain the old gas, put in new gas, use Marvel Mystery oil or Seafoam in the new gas to get the little parts in the carbs clean.
Then once we get her to fire off and run, we can do the oils, grease the neck bearings, etc.
Is there anything else about these older Evos that I should be aware of?
I am planning on UPSing a Napa air filter, some spark plugs,torque wrench. Chems I have to get on that side because of shipping BS. Are there any other parts I would need to bring because the nearest HD place is 35 miles away and its not the biggest dealership I have ever seen. Walmart sells batteries IIRC and we have one of those.
If the wheels are spoked, it uses tubes... replace those along with the tires.
Yank the carb, and clean it out COMPLETELY... replace the jets, they're too cheap to spend the time cleaning them all out.
Replace all the intake gaskets, they are likely dry rotted
Drain ALL of the gas out of the tank
Make sure the petcock is clean and free flowing... wouldn't hurt to replace the petcock to carb line and the tank cross overline.
Change ALL of the fluids before you fire it up. They're old. After you run it and get it warm, change it again along with a new filter. Oil can get a little sludgy after it sits for a while, and you will want to make sure you get it all out.
After that replace and grease whatever you want... do not for one minute believe that seafoam or marvel mystery oil cleans anything. They may stabilize your fuel but that's it... the rest of it is marketing bull **** and I don't care what anyone says about it either, except for TD.
Pull clutch plates and clean them; they gotta be pretty sticky after all this time of sitting.
Change brake fluids out, front and rear.
Pop the cap on the oil pump and clean the check ball and spring. Pull tappet screen and make sure it is clean.
If it has sat for as long as you mention, those engine gaskets are gonna leak...sooner than later. replasce them when the time comes.
If you get the chance take pics as you go. Documentaion of work is always a good thing. Post some pics of your progress.
- My first worry would be the pistons stuck in the bores...pull plugs and spray lots penetrating oil in cylinders...let it sit for a day..then move the bike back and forth in high gear to make sure the engine is free.
- If it was stored with the petcock closed...all the crap from the gas evaporating is likely to be in the bottom of the bowl...if you clean out the bowl BEFORE trying to start it, the carb MAY be fine.
- Changing the oil before trying to start it is a waste of time, as most of the oil is likely to be in the sump and will come out the breather when you crank it.
- After that, new battery, new gas. try to crank it and see what happens...make sure bike is in neutral as the plates in the clutch will be stuck together.
Drain the gas from the petcock and the carb bowl, refill with fresh, put in a hot battery, make sure you have oil in the tank, the primary and the trans, and fire it up. Watch the oil light. First time you put it in gear, it may try to launch if the clutch plates are gooped up, so point it in a safe direction and make sure the brakes work beforehand. Once it's running, the fluids are a lot easier to change.
I'd not run those tires 35 miles. I have a set of '98 tires in the garage that I'm changing this week, and trying to decide if I can putt-putt the 8 miles to the shop, or just drop the wheels. They have some pretty impressive cracks.
Only thing I would add to outlaw's is a little light oil in the cylinders before you crank it....
and 35 miles is a long way on 20 year old tires...
good luck..
Ds,
