Leaking lifter screen plug
Old Jun 4, 2014 | 04:08 PM
Jim Kraft's Avatar
Jim Kraft
Default Leaking lifter screen plug
I took out the plug to check the lifter screen the other day, and it has been seeping a little oil ever since. I replaced the "O" ring, but it is still seeping. Anybody have this problem? It is coming up past the "O" ring. Can I put in a thicker one? I just can't quite figure out why it is not sealing up. I have done this before without problems. By the way, I have never found anything in the screen.
Old Jun 4, 2014 | 04:34 PM
Spanners39's Avatar
Spanners39
Check the screen is seated properly, also check that new O ring is fat enough...you can go a bit fatter if need be.
Old Jun 4, 2014 | 04:51 PM
Jim Kraft's Avatar
Jim Kraft
Thanks Spanners. I just picked up the O ring from HD. The old one did not look bad but they are pretty thin. I will see if I can find one a bit thicker and see if that works. Thanks again.
Tailpipe
Oil Archive (no new posts)
Apr 13, 2020 10:51 AM
dduncan180
Aug 5, 2010 06:18 AM
mke125125
Dec 24, 2009 08:42 AM
azhole
Sep 9, 2007 01:01 PM
Two_Into1
21
Jul 14, 2006 05:13 PM
