Why Evo?
Old Nov 18, 2015 | 07:14 AM
  #231
Uncle G.'s Avatar
Uncle G.
Originally Posted by Harley-Davidson
Actually, S&S Cycle already does that. When H-D's patent on the Evo design expired, S&S took it and ran with it - improved it and builds NEW engines (not remans) that surpass the original Harley engines. Take a look at their V111 and T111 engines. They even build fully emissions compliant engines (the only ones I know of) that meet current 2016 emissions specs for new-build customs.
The S&S 111 cube engines are square (same bore and stroke) instead of being under-square (long stroke, smaller bore) like the H-D engines are. So they vibrate less because they have better primary balance. And they are torque monsters, producing over 100 lbs of torque at cruise rpm. And they come with a three year unlimited mileage warranty for the touring versions:
http://www.sscycle.com/go-fast-showc...-engines/v111/
http://www.sscycle.com/go-fast-showc...state-engines/
These engines aren't cheap and many people say "why do that when you can buy a new Harley?" BUT - there's a lot of people that don't want all the electronic BS in the new Harleys. And instead will gladly spend $12 Grand to have a classic that's reliable, outperforms the new Harley's, and turns heads because it's rare.
Many people say Harley dropped the Evo and went to the Twinkie because the Evo couldn't meet emissions. This is not true. S&S has been building them for over a decade - with carbs instead of fuel injection.
That's all well and good, but I'm not interested in a "torque monster". I'm quite happy with my stock 80" motor, and have been for 22 years. I'm just trying to keep it alive for another 200,000 miles (well, maybe being realistic-another 100,000 miles). By then, I'll be dead or too old to ride.
Old Nov 18, 2015 | 08:38 AM
  #232
Harley-Davidson's Avatar
Harley-Davidson
They also make the V80, which is a new manufacture direct bolt-in replacement for your stock 80" Evo:
http://www.sscycle.com/go-fast-showc...s/v80-engines/
Or if you want a smaller step upgrade in power and torque for pulling a trailer you can go with the V96:
http://www.sscycle.com/go-fast-showc...es/v96-engine/
Old Nov 18, 2015 | 04:06 PM
  #233
Lucky Luke's Avatar
Lucky Luke
So why did they (H-D) ?
Having to do something new purely for the marketing value of having done something new? Or to deliberately obsolete out something old for the sake of selling new models?
Thicker cases, wider bores, closer tolerance machining, what really does the single cam design give away at our level of performance?
Twin cam does have advantages if you are getting into asymmetric cam designs, but they don't really push that. And they are still *way* behind the times as far as variable or other advantages systems.
I think there are actually good arguments against not going crazy and sticking with healthy 80 or 96 ci engines. I can understand why someone wold not want too much.
More equals more wear.
That's what I learnt with big Japanese sports tourers when I started going through tyres at around 3,500 miles at both ends!
Yes, I'd start with a junker Evo with a dead engine, and swop it out for an S&S for my next project.
Old Nov 18, 2015 | 04:12 PM
  #234
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Personally I think it is much simpler than all that.
I was told HDs patent expired on the EVO and they needed a new motor to keep getting the royalties on the aftermarket motors.
If you ever want to know why a company does something follow the money.
Old Nov 18, 2015 | 04:18 PM
  #235
traildog's Avatar
traildog
Originally Posted by texashillcountry
If you ever want to know how to find me, follow the DIRT trail
Fixed it for ya........
Old Nov 18, 2015 | 04:24 PM
  #236
texashillcountry
Dirt don't hurt
Thanks for your help!!!!
Old Nov 18, 2015 | 05:25 PM
  #237
Harley-Davidson
Like texas said, it was all about money. And marketing. H-D needed to excite the Faithful - entice 'em into buying something new - and it worked. They sold more Twinkies in the first five years after they were introduced than they sold Evo's in the entire 16 years of their production run.
If Harley offered a new 2016 FXR Super Glide Custom with a S&S 80 or 96 with a Super E carb and IST ignition I'd be heading to my dealer before the first shipment arrived to see what sort of a deal I could make on one. And not a Dyna. I'm talking bring the FXR back. But alas - all they offer is the Dyna Low Rider with a High Output Twin-Cam 103. Not interested.
Old Nov 18, 2015 | 06:21 PM
  #238
Lucky Luke's Avatar
Lucky Luke
That makes sense, change it but only change it just enough to make a difference.
I'm not clear how the royalties system works though.
Old Nov 18, 2015 | 08:31 PM
  #239
texashillcountry
Dirt don't hurt
Very basically if you own the patent on something and you allow someone else to produce it they owe you money on every unit sold.
Once the patent runs out then anyone can produce it and they don't have to give you anything.
Bit of trivia the guy who invented the paper clip never made a dime on it because it didn't get popular until the patent ran out.
Old Nov 18, 2015 | 08:44 PM
  #240
Uncle G.'s Avatar
Uncle G.
The way I heard it, they never bothered to patent the motor design of the Evo at all. That's why there were so many Evo style motors from S&S, Rev Tech and others.
That lack of patent protection WAS a major factor in the decision to bring out the twin cam.
