Starter removal 1995 Electra Glide
Old Jun 24, 2014 | 07:19 PM
Maxdog2's Avatar
Maxdog2
Default Starter removal 1995 Electra Glide
I posted a while back about my whirling noise when starting the bike and was told the starter clutch/bendix was the issue. Well it is getting worse and the ole gal almost left me stranded. Got home and pulled the manual for instructions, thought I could just unbolt it and slide it out, but the manual says to remove the primary. Is this correct? thanks
Old Jun 24, 2014 | 07:26 PM
shadowchrome's Avatar
shadowchrome
Unfortunately yes. You have to take the screw out of the jackshaft. Make sure to replace the washer with the locking tab on the jackshaft when you put it back together if it is at all questionable.
Old Jun 24, 2014 | 07:28 PM
John5395's Avatar
John5395
+1. Easy but time consuming
Old Jun 24, 2014 | 07:34 PM
Maxdog2's Avatar
Maxdog2
Thanks for the responses. Sounds like a weekend and a few beers project.
Old Jun 25, 2014 | 09:38 AM
falconbrother's Avatar
falconbrother
I did this on a reduction geared sportster, looks like the same starter, I'm pretty sure it is. The installation looks like it's the same for a sporty. It's not a hard job at all. You may need one of those ball end allen wrenches to get to the bolts on the inside of the primary.
Joe_G
EVO
Sep 3, 2017 08:37 AM
Daren King
Jun 15, 2016 08:35 PM
John Fullington
Nov 10, 2013 02:11 PM
expoz85
Mar 10, 2012 05:11 PM
J.J.
Mar 22, 2008 10:23 PM
