intake leak
Old Jun 27, 2014 | 07:01 PM
Doug S's Avatar
Doug S
Armour-all and Seafoam have eroded the seals.... head gaskets are just around the corner... I hear twinkie baggers are not effected by them...
Ds
Old Jun 27, 2014 | 07:31 PM
traildog's Avatar
traildog
So, I had one stuck bolt and with a good suggestion from THC, and, figuring out I could yank the intake out if I removed the 3 loose bolts, I'm ready for new seals..... (and one boogered bolt.)
And a special package is on the way for THC......
Thanks THC. I do appreciate the help........
Old Jun 27, 2014 | 07:43 PM
jimbo285's Avatar
jimbo285
all the grief THC gives you and you are still nice. That's a real friend.
Old Jun 27, 2014 | 07:46 PM
traildog's Avatar
traildog
Nah, I hate him.........
Old Jun 27, 2014 | 07:47 PM
traildog's Avatar
traildog
Oh, btw THC.......I still want the 30 bucks......bwaaaaaaaaaaaaa..........
Old Jun 27, 2014 | 07:50 PM
bluharley's Avatar
bluharley
I replaced mine with hex head, much easier to get to with an open end wrench.
Old Jun 27, 2014 | 08:07 PM
Uncle G.'s Avatar
Uncle G.
I cut off a little piece of a 1/4" hex key about 3/8" long. I then placed it in the socket head screw with tweezers, then use a 1/4" combination wrench to remove the screw.
Old Jun 27, 2014 | 08:19 PM
D_gyver's Avatar
D_gyver
that's sorta what I use. I tack welded a short hex bit into a ratchet wrench
Old Jun 27, 2014 | 08:58 PM
Beemervet's Avatar
Beemervet
Every disposer comes with a hex wrench that just happens to be the correct size and angle for EVO manifold bolts.
Old Jun 27, 2014 | 09:24 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
What is a disposer?
