Starter or button?
Old Jul 2, 2014 | 08:53 AM
Uncle G.'s Avatar
Uncle G.
Originally Posted by aces&8s
Mr G, can I put a push button on a 97 WG?
the only reason not to is if your pipes are in the way of reaching the solenoid cover.
Old Jul 2, 2014 | 09:37 AM
Lakerat's Avatar
Lakerat
Both my Evo's gotts the button, cheap insurance.
Throttle_Jockey's Avatar
Throttle_Jockey
This is like the one I bought Ace.
http://m.ebay.com/itm/360965502071?nav=SEARCH
Old Jul 2, 2014 | 10:27 AM
Beemervet's Avatar
Beemervet
Originally Posted by 1550vt
I have had them on "anything" that has a solenoid cover....even my Twin Cams.
Not available for an Evo pre '91, but a resourseful rider can fab one.
Old Jul 2, 2014 | 01:23 PM
aces&8s's Avatar
aces&8s
Thanks for all the good input, much appreciated. I would like to keep the handlebar button working and install the solenoid button for emergency's. Doesn't sound to hard to do.
Old Jul 2, 2014 | 07:44 PM
machinehed's Avatar
machinehed
Default switches.
All good advice ... try spraying contact cleaner . wd40 or your choice into all your bar switches .
Disconnect the bat. and spray away until all that pours out is clear , let sit for a day or air blast if you have a compressor.
Old Jul 2, 2014 | 08:39 PM
aces&8s's Avatar
aces&8s
Thanks Machinehed, funny you mention WD40 & compressor today.
My lawnmower was coughing and flooding today so I dropped the float bowl and blasted everything with WD then hit it with compressed air. Put it back together and ran like a champ....
Old Jul 2, 2014 | 10:06 PM
Doug S's Avatar
Doug S
Sorry, WD-40 is bad for switches/electronics, plastic, things with small parts such as might be found in switches...
http://gizmodo.com/5932262/10-surpri...ver-be-sprayed
and not all contact cleaner is ok for plastics either, be careful and test first if you go that route..
Ds
Old Jul 2, 2014 | 10:58 PM
cowboy 51's Avatar
cowboy 51
just pull the control apart & clean the tab in there , it's just thin metal sand it real easy , then get the push button for a piece of mind
Old Jul 3, 2014 | 04:44 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Ds
That article is BS.
WD won`t hurt a thing in those switches.
