Starter or button?
Old Jul 3, 2014 | 05:03 AM
HGM's Avatar
HGM
My '94 Wide glide has always had switch issues, not sure why, maybe because my dad was **** about washing it. While it still looks new today because of it, the starter switch hasn't worked in 6yrs... I had even upgraded to the '96 style switches shortly before they failed..... Anyhow, I look at it as a anti theft device, of sorts.. It will only start from the little manual starter button.. I have one on my Ultra as well, will always have one on my bikes.. When you install it, take the plunger out and scuff the brass contacts, add some dielectric grease.. You wont regret it, one of the best accessories you can add for piece of mind..
Old Jul 3, 2014 | 06:14 AM
Doug S's Avatar
Doug S
That article is BS
Actually, parts of that article are b/s but the premis is not. WD-40 is the bane of the electronics and small machine industries... It does effect some plastics but what is worse, when the solvents evaporate it leaves behind a sticky film which attracks dirt. That film will over time, harden, making it extremely difficult to remove. Motors and devices with bronze bushings for bearings suffer, I replaced thousands of small motors that were commonly hosed down with the stuff to reduce noise and they ended up not working at all.
Believe what you want..
If you want a really good substitute, try this stuff.
http://www.lpslabs.com/product-details/560
Ds
Old Jul 4, 2014 | 07:08 PM
machinehed's Avatar
machinehed
Default Wd40
Ds
WD 40 is fine for almost all applications including plastic parts .
The product is defined as ., WD = water displacement , 40= 1940 the year it was developed and used in all the manufacturing processes that built our way to victory in World War 2.
The grey area now is that the company has tweeked the formule to be able to advertise that it is a basic do all compilation including the market for penetrating oil which it was not originally desighned for etc.
Its great stuff and use it to clean out switches as advised , it will leave a "slight" lubrication on the contacts that should be there anyway.
Sorry Doug but we disagree here.
Old Jul 4, 2014 | 07:42 PM
johnjzjz's Avatar
johnjzjz
i also have not found an purpose for it that it does not work including cleaning the work shop lifts and benches, vises ,and machines like the bridgeport ect ect
Old Jul 4, 2014 | 08:24 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by johnjzjz
if its the bike you have in the picture - install the mechanical push button and as long as the battery is good it will spin when pushed
Unless the problem is that the solenoid contacts are shot.
Old Jul 4, 2014 | 11:17 PM
aces&8s's Avatar
aces&8s
Put in a new HD relay and had no more problems. I also put Dielectric grease on all my relays and connectors. Looked at solenoid and all looked good.
Ill put in the solenoid button soon for em back up. Thanks for all the help.
Badluckbikes
EVO
13
Nov 4, 2016 11:54 AM
marktruckee
EVO
Feb 24, 2016 07:20 AM
genokelly
Engine Mechanical Topics
Aug 30, 2014 07:54 PM
roadking5555
Jul 24, 2012 05:27 PM
bigzdogz
Apr 28, 2010 08:52 PM
