85 EGC with a bad ignition switch
Old Jul 13, 2014 | 03:34 PM
jrotis215's Avatar
jrotis215
2nd Gear
Default 85 EGC with a bad ignition switch
Got a bum ignition light switch on an 85 classic. As you all know, and I had to find out, there warn't many a dose mamma jammas made afore dey wer discontina'd.
So...is there anyone out there with some experience with replacement switchs for this even if it means relocating to a different place on the bike. I would still like to have the ignition and ignition with lights as separate positions on the switch.
Tanks fer da 'elp...
Old Jul 13, 2014 | 05:01 PM
machinehed's Avatar
machinehed
Default Orrdd, Duufford @ Yemitty Skittles ign. switch.
She is 29 years old and the contacts in the ign. switch are probably dirty.
Disconnect the battery , buy a can of WD40 , use the long tube included and spray into all your switches while activating the switches until what drains out is clear. Let sit for 24 hrs. then reconnect the battery . Go for a ride .
Is all well now ?
Old Jul 13, 2014 | 07:02 PM
jrotis215's Avatar
jrotis215
2nd Gear
Machinehed She's old but she's a great ride. Thanks for the input. I had thought about trying to take it apart and clean it up, but the local tech who also has an 85 said they were not rebuild-able. I will try what you suggest.
Old Jul 13, 2014 | 07:08 PM
Stiggy's Avatar
Stiggy
Tedds Cycle / Tedds V-Twin (NY) buys up many of Harleys obsolete parts to resell them to you at a substantial profit. But if you need it you need it. Check there first.
Bikerzamm
Apr 20, 2019 09:10 AM
steve. m
Apr 11, 2016 08:23 PM
PKS98S
Sep 3, 2012 08:20 AM
06getsome
Sep 2, 2010 06:55 PM
Uncle Scrooge
Jun 4, 2007 08:43 AM
